I'm preparing to migrate three virtual chassis. Each virtual chassis contains two members connected with two DAC cables. These virtual chassis are connected to a OS6900 core network (no spb configuration) that will be updated soon. These three virtual chassis have the following configuration:
-> show configuration snapshot all |grep ^spb
spb bvlan 4000-4003 admin-state enable
spb bvlan 4000-4003 name "AutoFabric 1/1/2020 00:38:39"
spb isis bvlan 4000 ect-id 1
spb isis bvlan 4001 ect-id 2
spb isis bvlan 4002 ect-id 3
spb isis bvlan 4003 ect-id 4
spb isis control-bvlan 4000
spb isis interface linkagg 127
spb isis admin-state enable
How can I tell if this configuration is being used? Will it cause problems with the update?
I read on the forum that there's the auto-fabric admin-state disable remove-global-config command to remove this configuration. Is it safe to do so?
These virtual chassis manage VLANs. There is somes linkagg and spantree is mode flat.
Thank you in advance for your help.
