Low voice level on analog trunk lines.
mystry
Post by mystry »
Does anybody have an idea, how to increase the voice level on NDDI2 board.
Voice level is very week. Either you talk from Analog set or Digital set.
tincho.rn
Re: Low voice level on analog trunk lines.
Post by tincho.rn »
Hi. Go to Trunk Groups/Descend Hierchary/Trunk Group/Descend Hierchary/Trunk ... for the NDDI check the Trunk COS you are using (usually 0,1,2,or 3 for NDDI). Then go to mgr-->External Services/Trunk COS ... select the correct trunk cos, and change Line Type = Long Line. Reboot the NDDI. Check if it works. regards.
ACSE R11
OT R2.0
mystry
Post by mystry »
Thanks. I tried the same, it improve somehow but still not acceptable.
Any other suggestions.
Aazyzz
Post by Aazyzz »
Go To MGR >Trunk Group >D/H> Trunk group > R/M> select the trunk group number> ctrl+v
Change Use of volume in system from +YES to +NO
increase the Local Volume (dB) : 3/6/9
Return to “ON SITE TROUBLES”
