How install DECT station
misiekk
Post by misiekk »
Hi everybody I'm new on this forum so I would like to welcome eweryone. I have question about DECT station. I don't now how create new DECT station in OXE. Pleas give mi few hint. I read documentation but I found only text about phisical connection. Thanks
mgsox
Re: How install DECT station
Post by mgsox »
hi
these are the steps
mgr/Users/Create -->
x Directory Number : 978 x
x x
x Directory name : test2 x
x Directory First Name : -------------------- x
x Location Node : 1 x
x Shelf Address : 255 x
x Board Address : 255 x
x Equipment Address : 255 x
x Set Type + GAP + x
x Entity Number : 1 x
x Set Function + Default x
x Profile Name : --------------- x
x Key Profile + None x
x Identifier of Domain : 0 x
x Language Id. : 3
x x
x Secret Code : **** x
x Confirm : **** x
after creating do command
(1)xa000001> dectsets
you should get something like that
Neqt=01038 Nbr=978 IPEI=00007360007414 TSC UA V01.51 PLI 30
use command " dectinston <ext. No.> " to install the dect set.
no specific base station is needed.
open the dect set and press ok for everething the dect 'ask' you.
let me know if you need any more help
good luck
misiekk
Post by misiekk »
Thanks for Your answer. But I wrong describe my problem. I have problem with instalation IBS base station (no DECT station) sorry form my mistake. Did You know how install new IBS base station in OXE?
mgsox
Post by mgsox »
ok no problem
first you go
mgr/Dect System --> Radio base type + IBS
then
mgr/Dect System/IBS System --> Pari Value : 10000400004
then
mgr/shelf --> Pari Number + Pari IBS
then
mgr/Shelf/Board/IBS/Create -->
lqConsult/Modify: IBSqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Shelf Address : 1 x
x Board Address : 1 x
x Equipment Address : 14 x
x x
x Radio Part Number : 0 x
x Location Area : 0 x
x Location name : -------- x
x Line delay + Short line (0-400M) x
x Number of UA link : 2 x
x IBS generation + IBS 2G x
x Antenna diversity + YES x
x Odd slots + YES x
x Base in noisy audio environment + NO x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
NOTE allways programm ibs stations in even position on board e.g. 0,2,4,6,....
good luck again!!!
misiekk
Post by misiekk »
Thanks for Your help. Now everything working good. Best regards
lakachew
Post by lakachew »
when i install it the dect says accepted but on the dect display there is nothing? Anyone who knows about this problem i need help!
m0jtaba
Post by m0jtaba »
hi , are you folowing the "dectinston " command ?
