Hello Alcatel-Unleashed Community,
i have a question how can i reset a Alcatel-Lucent 8028s ??
I saw the handbook but i couldn't find nothing with reset.
King regards
oguzhan002
How to reset a Alcatel-Lucent 8028s
Re: How to reset a Alcatel-Lucent 8028s
Reset what?
To reset the Alcatel-Lucent 8028s Phone
The phone give it's information from CPU.if you mean you want to remove a number and it's configuration from it you must delete mac address in configuration or use "out of service" prefix.
you can also reset the IP parameters in the "IP memory" menu in the phone.
As I know there is no other extra information that can be reset.
Yes i want to reset the Number. How can i do that ? Delete the MAC Adress in Configuration ?
You want to reset number for what?
You want to use another IP set on the same number - delete MAC address, connect another set, enter Dir Number.
This number not needed - you can delete "user" .
hi guys, any idea on how to make factory reset of a 8028s. i have a new set out of the box and for my surprise its in sip mode. when i enter the admin menu it ask for a password. so i guess its better to make a factory reset right,
i have tried to check documents from ALE web page but nothing is coming out, so if there is any one who can help on this it will be great.
thanks in advance.
thanks in advance.
Default password for sip mode phone is "123456"
