Problem download binary to 4038
You found one ?
You know about one ?
Share it !
thkim81
Re: Problem download binary to 4038
Post by thkim81 »
I have same problem. I installation Ver 9.1.605 16c in south korea.
All IP touch phone 120EA 4038EE but some IP touch phone is bad status.
and then I guess the first PC & IP touch duplex .
PC network duplex static change 100MB full and IP touch auto -> 100MB full.
after next day, I check the problem phone. so some IP touch is Normal. bad status is changed normal.
but last two IP Touch phones are same status.
I connect the Telnet in Phone.
reset command excute.
but it's not efficent.
How do I change the Normal IP touch 4038EE?
Is anybody hint give to me? or problem solution.
thanks.
Mr T
Post by Mr T »
So is there any news to a fix for this issue. Currently seeing this with 4038's on i1605.21.
If someone could post an update, that would save me a call into TAC :)
Thanks.
a.neumann
Post by a.neumann »
After several Weeks of observating this Case thru Alcatel, after dozzend of Traces etc...
The Final Answer from Alcatel:
We have not found anny Softwarebugs.
It is an Hardwarefault, please send the Phones to Alcatel for Repair or change....
Best Regards
Mr T
Post by Mr T »
Thanks for the update. I was playing around with the 4038 that was having problems, I did a phone test on it through the menu tab and the Bad status went away ????
Guess I'll see if that fixes it for good.
matt
Post by matt »
there is a known problem with some sets that only have 8Meg of flash and cannot store the SIP code for the dual stack mode of the newer releases. If you used "lanpbxbuild -auto" this adds a SIP binary load line to the lanpbx.cfg that needs to be removed for the 4038 to load corretly.
At any rate, you can force a load of an iptouch via telnet
1. enable telnet in item 15 of ippstat on the desired set
2. telnet to the set's IP@
3. use the command "dwl go"
thanzeel
Post by thanzeel »
is there any other method where i can load in a single shot.?
thanzeel
Post by thanzeel »
is there any other method where i can load in a single shot.? for multiple phones?
Return to “Bugs & Security issues”
