Hi guys!
I’m newbie in OXE universe and I have some doubts.
I have two COS for different extensions that need to receive external calls. For COS 2, the extensions numbers are 2xx. For COS 3, the extensions numbers are 3xx. They do not have connection. From another PBX to dial COS 2 extensions, I need to dial the prefix 010 plus extension 2xx. Then OXE receives 0102xx and forwards the call to extension 2xx. Likewise, to dial COS 3 extensions, I need to dial prefix 910 plus extension 3xx. Then OXE receives 9103xx and forwards the call to extension 3xx.
First question: How do I assign prefixes 010 and 910 as OXE's own to the corresponding COS?
Another situation: COS 2 extensions dial outside to other PBXs using the 9yy prefix plus the extension number, that is, 6 digits are sent through a given E&M trunk group. I need to add a new group of Q.SIG trunks that also route calls to 9yy so that the main output is through the Q.SIG trunk and the secondary output is through the E&M trunk.
Second question: How do I create different routes to the same destination?
Thanks a lot!!!
Prefix and route
Re: Prefix and route
For first question - not clear - you talk about outgoing PBX or incoming?
For incoming - usually you need to manage DID translator (translator/external numbering plan/ DID translator). If in incoming TG used "DID transcoding".
For second question - you have two option:
- route call via QSIG TG and declare in QSIG TG overflow TG (E&M)
- use ARS feature
- use ARS feature
Vad,
Sorry about my delay to answer you.
Yes, for my first question I was talking about incoming calls. I tryed to do what you said, but it didn't work.
For the second question, I used your first option. It seemed easier and It worked very well.
Thanks so much!
Thanks so much!
If your line between PBX - IP, ISDN etc - you can use "t3" command (trace). You will see - dialed or received numbers etc. And can explain or understand more exactly - what is you problem.
