Cannot access to ISDN trunk OXE
hnorbi
Re: Cannot access to ISDN trunk OXE
Post by hnorbi »
I don't known what is 2-10-0, because is on an external cabinet, so I set 3-2-0 for physical access.
(1)bankop_b> config all
Thu Oct 18 09:20:27 CEST 2018
Crystal 0 :
| 0 | 6 | CPU6|---------- | REG NOT INIT | BAD PCMS CODE |
| 0 | 10 | CPU_CS|---------- | IN SERVICE | BAD PCMS CODE |
> Reference rack not set
Crystal 1 :
| 1 | 0 | UA_FICTIF| | IN SERVICE | NO PCMS CODE |
Crystal 2 :
| 2 | 0 | GD|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 1 | GA|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 2 | MIX448|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 6 | PRA T2|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 7 | PRA T2|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 8 | CS|---------- | CALL SERVER | BAD PCMS CODE |
--- Inter Crystal Topology ---
| CR | CPL Type Role Free/Tot Role Type CPL | CR |
|002 | 00 -GD (INT_A ) === 78/78 === ( MAIN) MEX - 00 |003 |
|002 | 00 -GD (MAIN ) --- 24/24 --- ( INT_A) INTIPA - 01 |019 |
Crystal 3 :
| 3 | 0 | MEX|---------- | IN SERVICE | NO PCMS CODE |
| 3 | 1 | GA|---------- | IN SERVICE | BAD PCMS CODE |
| 3 | 2 | MIX448|---------- | IN SERVICE | BAD PCMS CODE |
| 3 | 3 | GA|---------- | IN SERVICE | BAD PCMS CODE |
| 3 | 4 | UAI 8|---------- | IN SERVICE | BAD PCMS CODE |
| 3 | 6 | APA 8|---------- | IN SERVICE | BAD PCMS CODE |
|003 | 00 - MEX (MAIN ) --- 78/78 --- ( INT_A) MGD - 00 |002 |
Crystal 18 :
| 18 | 0 | GD|---------- | REG NOT INIT | BAD PCMS CODE |
| 18 | 1 | 4645|---------- | REG NOT INIT | BAD PCMS CODE |
Crystal 19 :
| 19 | 1 | INTIPA| | IN SERVICE | NO PCMS CODE |
| 19 | 2 | INTIPA| | OUT OF SERV | NO PCMS CODE |
| 19 | 3 | Z_FICTIF| | IN SERVICE | NO PCMS CODE |
|019 | 01 -INTIPA (INT_A ) === 24/24 === ( MAIN) GD - 00 |002 |
From your t3 trace
| (802333:000023) Physical-Event :
| long: 54 desti: 0 source: 0 cryst: 2 cpl: 10 us: 0 term: 0 type a7
| tei: 127 >>>> message received : SETUP [05] Call ref : 15
You have incoming call - shelf 2 coupler 10 access 0.
For outgoing call - you use shelf 3 coupler 2 access 0.
My questions:
- incoming call (3-2-0) - works?
- or you say about Ok incoming calls via 2-10-0?
- or your t3 trace - from another PBX
hnorbi
Post by hnorbi »
Okay, But the incoming calls, came from 3-2-0. Physically connected the cisco into 3-2-0.
hnorbi wrote: 18 Oct 2018 05:45 Okay, But the incoming calls, came from 3-2-0. Physically connected the cisco into 3-2-0.
1) Can you show t3 trace for incoming call (via access 3-2-0)
2) Check outgoing call (3-2-0) when exist incoming call (3-2-0)
hnorbi
Post by hnorbi »
Hm-hm
Someting went wrong.
trkstat 2 10
says, 2-10-0 contains an another trunk, but I don't known why.
If I call this trunk, It works.
So... I don't known what I dit it. And why. So... I'm refresh the doc, I missed it someting.
hnorbi
Post by hnorbi »
Shit-shit-shit.
I checked twice... simply changed the cabinet's order in the rack. Both cabinet's 2 position have MIX card... I checked twice...
Thanks! I will continue the things with the correct physical port.
Return to “Trunk Groups”
