Hi, I have the same problem, I tried searching for the password in documentations but couldn't find it.
Could you please send it to me on support@comsec.com.mt
Wallace
statistics manager - password problem
Re: statistics manager - password problem
for anyone having this problem :
the password is the administrator default password. If not working try reseting all passwords to default and reinstall the statistics manager.
That is what I did and it worked out.
Regards#
Wallace
Regards#
Wallace
- maria.para
Hello ,
Can you please help me by sending me the ACD statistics password at mparaskev@gmail.com?
I have the same problem.
Thanks in advanced!
Thanks in advanced!
- maria.para
I tried with the administator password but it doesn't accept it!!!
- tot3nkopf
Do you have license for statistics application and HDD on your PBX?
I have the same issue can you email the password to gcraven@talk21.com. thanks in advance
the password is the default admin password. If it doesnt work go into the system and reset the passwords and reset also the pabx. You should work like this.
Wallace
Wallace
Hi Malik,
i am also having the same issue, could you send me the password for the statistics manager, my email is: acolcha@hotmail.com
