Login Issue with OXO connect Power CPU EE
ogunkua
Post by ogunkua »
I tried login into a new Power CPU with a cross cable on the LAN port. using OMC with default IP : 192.168.92.246& default password : Pbxk1064. the system returned with a warning "Login error- "WRONG PASSWORD"; its a new CPU. am able to ping successfully the default IP; Can someone help me, if I am missing something here. Thank you all in advance
Everyone needs help to succeed!
emilio.grieco
How we can READ LICENSE FROM CPU BROKEN
Post by emilio.grieco »
HI
I have a Power CPU release 8.00 The CPU doesn't run and doesn't setup all functionalities I need to do the LOLA but in this way I loose LIECENSE. I don't have license file. Can I make something to read the license fron the CPU ?
Emilio
Return to “GENERAL”
