7210 SAS-D boot failing
bryan_lumpkin
Post by bryan_lumpkin »
I have a 7210 SAS-D that will not complete its boot cycle. It powers up, and I am able to console in. No matter what changes I make the switch just keeps looping through this process. I did notice there is a message saying the EEProm is not valid and I was wondering if I just have a bad switch or if I am missing something.
Alcatel-Lucent 7210 Boot ROM. Copyright 2009-2012 Alcatel-Lucent.
All rights reserved. All use is subject to applicable license agreements.
Testing ROM load area...done
Relocating code...Jumping to RAM
Performing second stage RAM test....passed
*** Card EEProm is not valid
Bootlog started for Version C-V-5.0.R2
Build V-5.0.R2 bootrom/mpc 7xxx
Built on Thu Dec 20 21:20:31 IST 2012 by builder in /home/builder/5.0B1/R2/panos/main
?Attempting to load from file cf1:/boot.tim
Version L-7.0.R5, Mon Apr 20 14:09:58 IST 2015 by builder in /home/builder/7.0B1/R5/panos/main
text:(5347008-->18339572) + data:(1039104-->5262104)
Starting at 0xb000000...
PCIe: Port 0 Link UP
Total Memory: 512MB  Chassis Type: sas  Card Type: badami_7210
TiMOS-L-7.0.R5 boot/mpc ALCATEL SAS-D 6F4T 7210 Copyright (c) 2000-2015 Alcatel-Lucent.
All rights reserved. All use subject to applicable license agreements.
Built on Mon Apr 20 14:09:58 IST 2015 by builder in /home/builder/7.0B1/R5/panos/main
TiMOS BOOT LOADER
readRtc returned error
Switching serial output to sync mode...   done
Looking for cf1:/bof.cfg ... OK, reading
Contents of Boot Options File on cf1:
    primary-image      cf1:\7.0R5\both.tim
    primary-config     cf1:\new.cfg
#uplinkA Port Settings:
    uplinkA-port       1/1/1
    uplinkA-autoneg
    uplinkA-duplex     full
    uplinkA-speed      1000
    uplinkA-address    0
    uplinkA-vlan       0
#uplinkB Port Settings:
    uplinkB-port       1/1/2
    uplinkB-autoneg
    uplinkB-duplex     full
    uplinkB-speed      1000
    uplinkB-address    0
    uplinkB-vlan       0
#System Settings:
    wait               3
    persist            on
    console-speed      115200
    no  console-disabled
Hit a key within 1 second to change boot parameters...
Configuring Network with uplinkA Port Setting.....
Primary config file present at: cf1:\new.cfg
Index file present at: cf1:\new.ndx
Sap Index file present at: cf1:\new.sdx
Primary image location: cf1:\7.0R5\both.tim
Loading image cf1:\7.0R5\both.tim
Version B-7.0.R5, Mon Apr 20 14:11:07 IST 2015 by builder in /home/builder/7.0B1/R5/panos/main
text:(36273888-->131545080) + data:(4630752-->21719220)
Executing TiMOS image at 0x100000
TiMOS-B-7.0.R5 both/mpc ALCATEL SAS-D 6F4T 7210 Copyright (c) 2000-2015 Alcatel-Lucent.
Built on Mon Apr 20 14:11:07 IST 2015 by builder in /home/builder/7.0B1/R5/panos/main
   ___                    ___           ___           ___
  /\  \                  /\__\         /\  \         /\  \
  \:\  \        ___     /::|  |       /::\  \       /::\  \
   \:\  \      /\__\   /:|:|  |      /:/\:\  \     /:/\:\  \
   /::\  \    _\/__/  /:/|:|__|__   /:/  \:\  \   _\:\~\:\  \
  /:/\:\__\  /\__\   /:/ |::::\__\ /:/__/ \:\__\ /\ \:\ \:\__\
 /:/  \/__/ /:/  /   \/__/~~/:/  / \:\  \ /:/  / \:\ \:\ \/__/
/:/  /     /:/  /          /:/  /   \:\  /:/  /   \:\ \:\__\
\/__/      \/__/          /:/  /     \:\/:/  /     \:\/:/  /
                         \/__/         \/__/         \/__/
Card eeprom invalid
Resetting...OK
Return to “7210 SAS”
