SFM5-12/CPM5
SFM5-12/CPM5
I have a 7750 SR-12 and I am having a issue with the SFM5-12/CPM5 and the Fabric Speed with TiMOS-SR-13.0.R3. Is this CPM compatible. Every IOM3-XP that I put in says that the Fabric speed isn't supported.
Re: SFM5-12/CPM5
Hi, Shawn. If you've booted into SR-OS, then the CPM is compatible/supported. If you're getting messages related to support of the set-fabric-speed command, you'll likely have to upgrade your version of SR-OS.
Is there any more detailed information in the system logs?
Re: SFM5-12/CPM5
Hello Lo0,
Do you know is there a specific license for upgrading Timos R015/R016??
Or I just load the image then active software is enough?
Best regards,
Best regards,
Re: SFM5-12/CPM5
Just load the image
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
Christoffer
Nokia SRA #265
[/flash]
Re: SFM5-12/CPM5
Hello Stoffen
Thanks for your reply~!
If original version on SFM5-12 is Timos 13, still be okay if upgrade to Timos 16?
I worry only the license, config erased is okay for me.
Best regards,
Jeff
Best regards,
Jeff
Re: SFM5-12/CPM5
timos 13 is no longer supported...just go for timos 16... then check your chassis mode, AFAIK it should be "chassis mode d"
