Hi Team,
i am new with alcatel, Required little help with SDP. Below is the topology :-
R1(1.1.1.1)--------------R2(2.2.2.2)-------------R3(3.3.3.3)-------------------R4(4.4.4.4)
i have created a vprn service b/w R1 and R4 and a SPOKE SDP(using LDPoRSVP) is bind to vprn to reach R4. but SDP is not comming up.
1. RSVP LSP is created between R1 and R3. LSP is up and operational. LDP is enabled on all the interfaces as well.
2. TLDP session is Created b/w R1 and R3.
3. prefer-tunnel-in-tunnel and tunneling command is executed in LDP.
A:>config>router>ldp# info
interface-parameters
interface "to_r2" dual-stack
ipv4
fec-type-capability
prefix-ipv6 disable
p2mp-ipv6 disable
exit
no shutdown
exit
no shutdown
exit
exit
targeted-session
peer 3.3.3.3
tunneling
lsp "to_R3"
exit
no shutdown
exit
exit
no shutdown
A:>
A:>config>service>sdp# info
far-end 4.4.4.4
ldp
keep-alive
shutdown
exit
no shutdown
A:>config>service>vprn# info
route-distinguisher 8888:8
vrf-target target1
spoke-sdp 2 create
exit
no shutdown
A:# show router tunnel-table
IPv4 Tunnel Table (Router: Base)
Destination Owner Encap TunnelId Pref Nexthop Metric
2.2.2.2/32 ldp MPLS 65537 9 12.0.0.2 1010
3.3.3.3/32 rsvp MPLS 1 7 12.0.0.2 2000
3.3.3.3/32 ldp MPLS 65538 9 3.3.3.3 2010
4.4.4.4/32 ldp MPLS 65539 9 3.3.3.3 3000
Flags: B = BGP backup route available
E = inactive best-external BGP route
A:#
A:# show service sdp 2 detail
Service Destination Point (Sdp Id : 2) Details
Sdp Id 2 -4.4.4.4
Description : (Not Specified)
SDP Id : 2 SDP Source : manual
Admin Path MTU : 0 Oper Path MTU : 1488
Delivery : MPLS
Far End : 4.4.4.4
Tunnel Far End : 4.4.4.4 LSP Types : LDP
Admin State : Up Oper State : Down
Signaling : TLDP Metric : 0
Acct. Pol : None Collect Stats : Disabled
Last Status Change : 03/15/2015 10:54:01 Adv. MTU Over. : No
Last Mgmt Change : 03/15/2015 10:33:09 VLAN VC Etype : 0x8100
Bw BookingFactor : 100 PBB Etype : 0x88e7
Oper Max BW(Kbps) : 0 Avail BW(Kbps) : 0
Net-Domain : default Egr Interfaces : Consistent
Flags : TldpSessDown
Mixed LSP Mode Information :
Mixed LSP Mode : Disabled Active LSP Type : LDP
