OXE with a BPRA in Master / Network <==> OXO Compact
stefanc_DUP
DECT losses
Post by stefanc_DUP »
We have CPU6.2 and uses DECT4HB in two Remote ACT beacuse high trafic demands eg. 80 Sets and lot of traffic. (very crowded area).
The IBS on another ACT is choosen when the customer only uses less dectsets.
I cannot change the ACT remote RT-2 board synch to 200.
Where do I find the "Manage ACT Handover ...." (pherhaps a stupid quest.)
Thanks for your time.
Regards ... // Stefanc
snap.
DECT/RBS system - manage ACT handover=yes and decleare ACT No=0 (where CPU located).
For remote RT2 ACT manage for RT2 synchronization priority 200 and remove DECT4HB board (if you use this board before only for synchronization).
PWT/DECT system /RBS system
stefanc_DUP
We run now (Switched last night) ver 7.0 is your refered objects for a latter revision.
But under object: DECT/PWT ==> RBS Do you meen:
Inter-ACT Handoff or DTM Synchro
Where can I declare ACT 0
Thanks for your fast reply.
When you manage interACT handower=yes, you will see field where you can manage shelf number. If you give me you e-mail I send you technical communication about DECT. You can send you e-mail through private message.
Return to “ON SITE TROUBLES”
