Q-sig ans Samsung os500
spring
Post by spring »
Check the following settings
1. Digital Access
1.1 Sync. Priority: 200 for Master
1.2 Network Mode: Yes for Master
1.3 Tie Line Mode : No for non-Alcatel Product
2. Trunk Group
2.1 Q931 Signal Variant: QSIG
2.2 Channel Selection Type: (Change depend on remote system)
2.3 B Channel Choice: Yes for Master
2.4 Remote Network: 1~15
2.5 Translators > Network Routing Table 1~15 > Select QSIG
3. System > Other System Para
3.1 ISO Function: T for ISO, N for ECMA
3.2 Compatibility: T/F
seriosha
here is trace...!!
Post by seriosha »
--> Cleaning mtracer...
| 0 | ** | ** | * | ** | * | *** | 165 |
| 1 | ** | ** | * | ** | * | *** | 166 |
| 2 | ** | ** | * | ** | * | *** | 167 |
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
Traces Analyser activated
mtracer started ...
| (850744:005362) 998: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 54 desti: 0 source: 15 cryst: 3 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<<message> T2 : B channel 2 preferred
| IE:[6c] CALLING_NUMBER (l=12) -> 00 81 Num : 8126222222
| IE:[70] CALLED_NUMBER (l=2) -> 80 Num : 0
| IE:[7d] HLC (l=2) 91 81
| [95] Locking shift. codeset : 5
| IE:[32] EI_PARTY_CATEGORY (l=1) -> EXTENSION (1)
| (850745:005364) Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 3 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP ACK [0d] Call ref : 80 3f
| IE:[18] CHANNEL (l=3) a9 83 82 -> T2 : B channel 2 exclusive
| (850750:005365) 998: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 3 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<<message> 80 Num : 0
| (850754:005366) 998: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<<message> 80 Num : 2
| (850760:005367) 998: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| (850763:005368) 998: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| (850767:005369) 998: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| (850770:005370) 998: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| (850771:005371) Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 3 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 80 3f
| (850772:005372) Physical-Event :
| long: 75 desti: 0 source: 0 cryst: 3 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : 80 3f
| IE:[1c] FACILITY (l=55)
| [9f] Discriminator of supplementary service applications
| [aa] NFE (l=14):
| [80] Source Entity (l=1) End_PTNX
| [a1] Source Entity address (l=2)
| [80] Party Number (unknown) (l=0)
| [82] Destination Entity (l=1) Any_type_PTNX
| [a3] Destination Entity address (l=2)
| [92] UNKNOWN (l=1):
| [00] ??? analyse_alarm=1 (type)
| [a1] INVOKE (l=33):
| Invoke Ident. : 00ff (255)
| OP: ECMA RO_CALLED_NAME (1)
| [30] Sequence (l=22)
| [80] Name presentation allowed (l=18) ' Ъ002202'
| (850772:005374) 998: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 26 desti: 0 source: 15 cryst: 3 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<<message> [e3]
| INFORMATION ELEMENT NON-EXISTENT OR NOT IMPLEMENTED
| IE:[14] CALL_STATE (l=1) 04
| (850773:005375) Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 80 3f
| IE:[08] CAUSE (l=3) 80 e3 1c -> [e3]
In your configuration which one of the 2 PBX offers clock to the other ?(is your Samsung the master or you want to receive clock from Alcatel?). If Alcatel is the one who offers clock synchro set pryority to 7 let's say in it and 200 in Samsung side - you must have this option there too.
Hope that helps.
After ALERT message you PBX send message (from trace not clear this is STATUS message or not).
If status - system/ other system param/ external sign. param - Send Status for IE non-existent =no.
And in additional you can try (if problem not solved with previous item) - System - Reaction Receiving Message State - you can choose "ignore" for some state (f.e. Ignore ISDN Fault In Mandatory EI and so on).
seriosha
Oky
Post by seriosha »
I'm going to do that
spring
Post by spring »
According to the trace, you are using QSIG-ECMA mode. Check the Samsung system is using QSIG-ECMA mode or ISO mode.
seriosha
here is the settings
Post by seriosha »
Here is my setting for Q-sig
1. Digital Access
1.1 Sync. Priority: 255 (I can’t set to 200 cuz PRA in 3 -6)
1.4 CRC4 ON
2. Trunk Group
trunk number 88 (prof with overlapping)
2.2 Channel Selection Type: default
2.5 Translators > Network Routing Table 1 > Select QSIG
3.1 ISO Function: T (for ISO)
There is settings like ISO or ECMA on the Samsung system
It now not worked out
spring
Post by spring »
Sync. Priority 0 or 200 is recommended for connecting on ISDN Public Network because it is the Master clock for whole PABX. For private network, the priority should be greater than 0 for global sync. or 200 domain sync. e.g. 10 or 210
u can try to change the ISO function from T to F as well as Compatible Gf to F. System reset is necessary.
Which is the sync priority in the Samsung side? You must set sync priority of the Alcatel (becouse master = offering clock sync) greater than sync priority in Samsung side.
alurfe
Post by alurfe »
i think you are workin' on two pabx with different levels of q-sig services. reading the traces mybe Samsung is q-sig GF, but Alcatel is Q-sig BC. you can try configure q-sig GF on Alcatel.
best regards
Return to “GENERAL”
