Question about an ACSE exam
ibuza
Post by ibuza »
cavagnaro wrote:I don't think exam questions are repeated over the tests, i'll recommend to read all you can of OXO and practice.
ON the BPWS there are some tests:
Training and Certification --> Training --> Skill Assessment
and
Training and Certification --> Certification --> Practice Test
Some of these questions were in my ACSE Core exam. Do all the tests since even in ACSE Advanced IP there are questions that also apear in the ACFE exam.
Part of the courses at Alcatel University are some multiple choice tests. Some of those questions where also in the ACSE exam. So I hope you still have these tests from the courses.
Here you have 10 questions:
The CPU7 embedded ethernet interface can be disabled by a maintenance command. In case of CPU reset, the configuration is ?
- Always lost
- Lost if the jumper is installed on the board
- Always kept
- Kept if the jumper is installed on the board
Which system information does not belong to the system data base?
- MAO data
- LINUX data
- Binaries
- Accounting data
From R6.0, what kind of conferences are supported by the CPU-GD/GA board ?
- add-on only (not meet-me nor mastered)
- meet-me only (not add-on nor mastered)
- meet-me and add-on only (not mastered)
- meet-me, add-on and mastered
If you only need to change the subnet mask of the local Ethernet interface (il0), which command do you have to use ?
- netadmin
- ifconfig -a
- netadmin -m
- swinst
What type of off-hook routing can not be configured ?
- No routing
- Immediate routing
- Routing on no reply
- Delayed routing
The user 2200 has the connection category 0, 2201 the connection category 1 and 2202 the connection category 2. If the transfer category 1 is incompatible with the category 2 :
- 2201 can't call 2202
- 2201 can't transfer a call to 2202
- 2201 can't be transfered to 2202 by 2200
- 2200 can't be transfered to 2202 by 2201
If connection category 5 is disabled, the consequence of this is to .........
- make the Trunk to Trunk connection impossible
- make the outside calls impossible
- make the internal calls impossible
- make the calls between attendant sets impossible
On which of the following trunk line types is it not possible to dial outgoing ?
- Analog DDI trunk line
- T0 access
- Manual tie-line
- E&M tie line
Which CDT (Call Distribution Table) must be configured to reach the attendant set when using the "attendant call" prefix ?
- The CDT of the attendant
- The CDT of the attendant group
- The CDT of the caller's entity
- The CDT of the overflow attendant entity
What information is contained in the OPS files?
- The database
- The LINUX data
- The accounting data
- The software locks
Best Regards
Jörg
spring
Post by spring »
Thank ibuza. I already did many times on Training and Certification --> Training --> Skill Assessment
and
But I found that there are only a few questions on the web site. It is not enough to handle the exam. of ACSE IP Advance
I can recommend you to build a lab and test all you can. FEatures, how it works, why it fails, try to understand the architecture.
Build scenarios, see customers needs, try to recreate problems, etc.
That is the only way you will have all the knowdledge you need, in my opinion.
pls, ibuza, complement my answer :wink:
freedom
Post by freedom »
Normally if you had some practise, the exam should not be a problem. For the theoretical part; just think logical and of course know your system!
Good Luck with your exams!
spring
Post by spring »
Thanks Freedom. I have just passed the exam of ACSE Advanced IP course. From my experience on the Multiple choice, the Alcatel web practice does not help you because all the questions concern on IP, IP protocol, IP security and security protocols. I think that these questions should come from e-learning
Return to “GENERAL”
