SIP Trunk OXE <--> TrixBox
arminas
Post by arminas »
i have just increased trunks but it still give that error
┌─Error:───────────────────────────────────────────────┐
│ CANCEL to close this window │
│ Processing Failure │
│ OBJECT -1: Trunk Group ID: No free Hybrid Bus Access │
Maximum values in the installation
Users : 2124
1/2 com : 3503
Hit return to go on
These values depend on other parameters read in config.mao file
Users = Stations + Data Term. + Patients + 5(Substitution) + 150(HE-Minitel) + 1
0(Attendants)
Half-context = MAX (read value, calculated value)
1 Stations : 384
3 Data terminals : 1000
4 Patients (hospital) - Fictive users : 0
5 Trunks : 1000
8 Nodes in the network : 100
10 Shelves (migration excluded) : 5
11 1/2 com : 154
12 TS reserved for operators on INT/RT2 links : 4
13 Tables of R2 signalling translator : 1000
15 Data in R2 signalling translator : 1000
17 Abbreviated numbers : 4000
18 DECT Handsets : 250
19 Supervisable MCDU : 1500
20 Number of Sub-Networks : 16
21 Number of Network Set in Hunting Group : 300
22 Number of ARS route lists : 400
24 Number of areas (accounting duration) : 1000
25 Number of Charge Scales (accounting duration): 30
26 Supervisable Trunks / Trunk groups : 1000
27 Number of Network Supervisor : 0
28 Number of PIN : 100
29 Number of CSTA buffer - Monitoring : 1200
30 Number of CSTA buffer - Pilot : 1200
31 Number of CSTA buffer - Service : 500
32 Number of CSTA buffer - RSI : 1200
33 Number of CSTA buffer - Associate/Reference : 1500
34 Number of x25 command abbreviated numbers : 100
35 Number of called filter : 500
36 Maximum Number Of Account Codes : 2000
38 Number of S0 users / bus on UA : 8
39 Number of entities : 1001
40 Large number of fictive T0 (0/1) : 0
Values read in hardware.mao file :
41 Remanent size : 26429
42 Stand-alone : 1
43 Number of BLF : 0
44 Phone-book (x 2000) : 3
45 SBC : 0
46 4635X : 0
47 4630 : 0
48 4855 : 0
49 Hotel accesses : 0
50 ACD supervisor accesses : 0
51 Set display languages : 4
52 Maximum simultaneous casual conferences : 0
53 Large equipment capacity : 0
Value to modify (0 = Exit) :
where is the problem ? can you help
thanks
Have you done the reboot?
arminas
Post by arminas »
yes , of course but nothing changed.my release 9.0 ,is there other solution you suggest ? thanks
Our magic balls are still out of service, as requested before, please post logs...we can't be guessing forever.
Tincho, you're freaking nice.... Cause at some point I would have say "What about you take the documentation where it is well explained, and you give it a shot first?" :)
Maybe it's one of those days where I do not have patience..
arminas
Post by arminas »
i changed all ops files except *.swk with new ones and my problem is solved .thanks for help
arminas
Post by arminas »
oxe can register my ext. gw. there is no problem . also oxe can send invite message to ext. gw .but in this invite message oxe sends P-Asserted-Identity and because of this my operator drop my call.how can i configure oxe not to send PPI header in the invite message ?
Thnaks
tincho.rn
Post by tincho.rn »
frank wrote:Tincho, you're freaking nice.... Cause at some point I would have say "What about you take the documentation where it is well explained, and you give it a shot first?" :)
:):) You are right!!
Return to “SIP”
