Configuration problem
Check Hardware and limits/ Main cabinet
DFK
Post by DFK »
Hi Vad, it is CPIV and purchased a promo offer of OXO..Does CPIV by default contains VoIP card?
CPIV ? May be CPU-4? Quetion was not about main CPU (question was - you have one CPU or two, and have you VoIP board or not) - can you show main cabinet window?
About VoIP - Hardware and limits/ Main cabinet, right click on CPU board/ details
elkiwi
Post by elkiwi »
Hardware and Limits --> Main Cabinet. There's a list of boards installed on the OXO
Sorry I didn' see page 2!!
DFK
Post by DFK »
Hi all, Sorry for the delay reply.....This OXO doesn`t have any VoIP board with it..according to Alcatel representative we dont need VoIP board for Basic Pimphony as Promo offers contains 10 basic Pimphony license, is it correct? i dont need VoIP board for basic pimphony client??
If it is Ok then what IP should i insert while configuring PimPhony?
elkiwi
Post by elkiwi »
In that case CPU IP
ileana
Post by ileana »
Hello DFK, well.. If you want to check your boards in the OXO, try to login in OMC with the IP of CPUboard an the password that you´ve configured. Then in Hardware&limits/ Main Cabinet you con check the boards of the system and daughter boards.
If you need to know the IP address of each board (CPU or CoCPU) follow this route: Hardware&limits/LAN-IP Configuration/Boards.
maverick
Post by maverick »
Hello
ok, if you check the hardware, licenses, and all its correct. the problem maybe its in your PC, disable firewall in your PC, disble antivirus, or check firewall in the LAN. I had problems with this issues in diferente OS plataforms.
regards.
Return to “Configuration”
