R 9.1 CS-2 & GD-2 wont load with PC Installer 2.24???
MTConsulting
Post by MTConsulting »
yes new HDD and new CS-2, I dont see the menu your getting Joel, I have checked the HDD and it IS a supported model, but is blank. Is there some pre-loading that needs to been done to new HDD's?
**PROBLEM SOLVED** Windows 7 not compatible with PC Installer 2.24
MTConsulting
Found issue!!
FXCKING Windows 7 wont work with 2.24 PC Intsaller!!....loaded VMWare and created an XP machine, added all other needed software to it and bingo it started to boot off my VM-XP machine straight away!
Thanks for the help Joel, hopefully France will fix this....by 2012!!
Time for BEER!!!!!!!!!!!
OXE_4400
Post by OXE_4400 »
Why Yoy use 2.24? Exist 2.26 version
MTConsulting
I "Yoy'sed" 2.24, 2.25 and 2.26 and NONE worked? I was loading R9.0 and ALWAYS use the PC Installer that is part of the release to perform an install.
I have 2 new IBM appilance servers and 2 new CS-2's that will not load via Win7 or XP?
I am lodging an e-Service with France to find out why.
alcatelspares
Post by alcatelspares »
You are only looking at the AP screen you need to connect a to console port screen for you to be able to see the boot from etherent screen
nowi
Re: R 9.1 CS-2 & GD-2 wont load with PC Installer 2.24???
Post by nowi »
with Windows 7 launch the PCInstaller in compatibility mode XP SP3 and as Administrator! Go to the Start menu and right click on the PCinstaller icon.
At least this works for me.
Ciao,
Nowi
Czar666
Post by Czar666 »
Nowi, works for me too. Thx.
FN_DK
Post by FN_DK »
After quite few hours of troubbleshooting I found this post.
What I found is:
Loading from WIN7+PCInstaller 2.26 you can install a static patch WITHOUT running as winXP+admin.
Loading from WIN7+PCInstaller 2.26 you can install a mainrelease WITH running as winXP+admin.
Think this is what have confused some (incl. me).
Once again, thanks to the ppl on AlcatelUnleased
OXE_4400
Post by OXE_4400 »
Exist 3.2 version:
Readme: OmniPCX ENTERPRISE PC INSTALLER v3.2
ANOMALIES REPORTS CORRECTED
RA crms00218529 Some Chinese String label on PC Installer cannot show righ
RA crms00218531 Need to manul reboot the pbx after a linux+callhandling installation when using Pcinstaller on Win7.
RA crms00218540 PCinstaller will not automatically change it start language after System change it locale
RA crms00232208 Win7: For successive installation of patch in Call server windows7 PC needs restart which shouldn't be the case.
RA crms00234300 OmniPCX Installer on Win 7: Console window "C:\PROGRA~1\ALCATE~1\OMNIPC~1/bin.ftpd.exe" pops up.
RA crms00240257 OmniPCX Installer on Win 7: CS-2 installation fails.
RA crms00240260 OmniPCX Installer on Win 7: Warning message "Browser: service is not started" pops up.
-------------------- journal : version 3.1 ----------------------------
Readme: OmniPCX ENTERPRISE PC INSTALLER v3.1
RA crms00200392 PC Installer on Windows 7
Return to “Media Gateway”
