IBM Appliance servers, stopping at Linux.ram loading???
alex.marete
Syslog PCX Installer
Post by alex.marete »
Hi VAD
here is the log file can you advise on anything that you might see ?
Pedro
charpdy
Post by charpdy »
are you using a direct connection from pc-installer pc to appliance server ?. it looks like there are more than 1 dhcp server available.
The thing about not loading part 2, i have seen many times, usually when i forget to choose appliance server instead of alize.
/Per
pgemelgo
Post by pgemelgo »
Hi All
Thank you all for the valuble input. We got it working!!!! WWOOOHOOOOO, it was the PC INstaller Version that we were using that was wrong, but now working.
Thanks all.
MTConsulting
Post by MTConsulting »
Hi Freedom,
Thanks for your help mate, next time I will climb in behind the cabinet myself and see if there really is a serial port instead of taking some one elses word for it!!!!
Hooked up serial to lappy, hit N for security question etc...runs like a beauty now...thanks again!!!!!
freedom
Post by freedom »
NO problem, glad that I could help you.
alex.marete
I had exact problem on R9.0. you must use PC installer 2.24. There is nothing to do with Redhat. I use Win XP to load the versions onto the IBM servers.
Locked
Return to “Media Gateway”
