I will try to push it in further when I get home. I thought CPU light was supposed to be fixed and blink when working? The CPU light is fixed on everything else?! (Inlcuding Z24, NDDI, Even CPU3)
ok, you probably need to connect a serial cable to it, if the board is not configured it will not come up at all. There is probably a CBRMA connection box, if so, coneect to A0. If you get a login prompt we are almost there,
who was the previous maintainer?
what customer is it, i may know the passswds for access, if not, get a login & we can work around it
