4760 - unable to connect to server
Rollerskatepaul
Re: 4760 - unable to connect to server
Hi All,
I'm having the same problem with the 4760,
nmcVersion=4760.5.1.06.03
Current License id
Version = 11
OS version
OS Name: Microsoft(R) Windows(R) Server 2003, Standard Edition
OS Version: 5.2.3790 Service Pack 2 Build 3790
Unable to connect to server port nummber 636
I also used port nummber 389 this also does not work.
This is the log out put from C:\4670\log\NMCsvc_mgr.log
[1/12/2011 11:28:09 AM] 6844 svc_mgr: Error: connection to LDAP server failed (error 85: Timed out)
[1/12/2011 11:28:09 AM] 6844 svc_mgr: closing LDAP connection
[1/12/2011 11:28:09 AM] 6844 svc_mgr: Error: cant extract last threshold for LDAP
[1/12/2011 11:28:09 AM] 6844 svc_mgr: Error: cant extract last threshold for SQLA
[1/12/2011 11:28:10 AM] 6832 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
Kind regards
Paul
Current License id
Version = 11
OS version
Kind regards
Paul
luis.molinas
Hi, I had this same issue after to upgrade OV4760 5.1 to 5.2. But I can solved this issue after to delete all log files from c:\4760\log forlder (for delete I needed to stop the "NMC service manager"). Then I reboot the PC and the issue was solved.
I hope to help you!
Regards.
I hope to help you!
Regards.
luis.molinas
In the NMCsvc_mgr_1.log I had the next line events:
[12/03/2015 11:57:57] 2360 svc_mgr: starting...
[12/03/2015 11:57:57] 2360 svc_mgr: controlled services won't be allowed to interact with desktop
[12/03/2015 11:58:57] 2364 svc_mgr: Error: connection to LDAP server failed (error 85: Timed out)
[12/03/2015 11:58:58] 2364 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
[12/03/2015 11:59:01] 2364 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
Regards.
Regards.
