Multiple analog sets keep ringing by themselves at night without a wakeup
kleanthis25
Post by kleanthis25 »
sadim wrote:Make a ahl trace and check the messages
thanks . we found the solution to our problem .we diverted all the extensions we had a problem with , to the main console and discovered the fault extensions.the problem was wiring. thank you all for the help.
mejust
Re: Multiple analog sets keep ringing by themselves at night without a wakeup
Post by mejust »
Guys
I know that this log is old , but it seams that I have the same problem, In my case I don´t think that the problem is cabling .
This happens occasionally and always with different extensions . Is there any way that we can see on the OXE the wakeup logs ?
Thks in advanced.
Return to “MAIN”
