Forget OXE 9.0 password
Re: Forget OXE 9.0 password
thank vad for quick response,,, i think i will just clone the database
- Tha Tawa'S
HI,
Has someone the "password recovery for linux.pdf" available ??
Regards.
Regards.
It follows. Check it it is this one you want.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
- Tha Tawa'S
Thank you very much !
Sorry for my late answer.
aadeshjadhav
Dear Vad
After using this method:
root (hd0,4)
kernel /boot/vmlinuz root=/dev/hda5 console=ttyS0,9600 panic=5 single init=/bin/bash
boot
-i get this following message & system got rebooted
IP: routing cache hash table of 8192 buckets, 64Kbytes
TCP: Hash tables configured (established 262144 bind 65536)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
802.1Q VLAN Support v1.6 Ben Greear <greearb@candelatech.com>
vlan Initialization complete.
request_module[block-major-3]: Root fs not mounted
VFS: Cannot open root device "hda5" or 03:05
Please append a correct "root=" boot option
Kernel panic: VFS: Unable to mount root fs on 03:05
<0>Rebooting in 5 seconds ..no switch back.
root (hd0,4)
boot
ok...
two things can be happen.
1. the system uses other partition (because of an update on secondary partition)... then try to use /dev/hda6 as root
2. the system uses appliance server and the cabeling internal set the harddisk on the 2. controller. if this is the case try to use /dev/hdb5 or /dev/hdb6
regards...
regards...
