How to view Prog.Keys of a User ?
zetor2000
Re: How to view Prog.Keys of a User ?
Post by zetor2000 »
vad:
I think the use of the 4760i is depending on the OPS. As far as i know there is a flag in the mgr/system/other system parameters/use of 4760i... and i suppose the use of 4760i is OPS dependent.
kaseOga
in the late 90s there were a management software named chameleon. The 4760i is the legacy, or similar... in the chameleon, you could set up viewing settings. I think, you should try to check the right click menu... in the 4760 configuration window, where you see the attributes of an extension. I suppose there are some "tree view parameter" or similar.
zetor2000 wrote: vad:
No OPS associated. You need to enable the flag and also the use of the web server --> for security reasons it is recommended against this as per one SA (Security advisory)
zetor2000 wrote: kaseOga
Old times...
Barrykeery
How to view Prog Keys of a User
Post by Barrykeery »
I would like to write shell script but I use window7 then how can I test and run it?
Return to “Linux tricks”
