X25 through OV 4760
sadi_seemi
Re: X25 through OV 4760
Post by sadi_seemi »
hi haroun.
now i can connect my nodes through omnivista.change the netmask 255.0.0.0 to 255.255.255.0 on all nodes. thanks to help me.
you'are the wellcomed
sorry for the big replay with lot of inforamtion becuas ei was very busy , i give the max of parameters to be checked lol
by the way can u poste your dbcheck command screren shot ?
sadi_seemi
sorry brother there is no internet facility i can note the data and write only text.why u need this.
to see if all nodes ares well configured under x25.
stuff from central node ifall tunels are declared under x25 you will manager users of the nodes under users of local node lol
sadi_seemi
i will try my best haroun
sadi_seemi
hi haroun
dbcheck command executed display
check database /........................................../
only show like this nothing more data.
means no error on your DB
SO all nodes are defined under X25/network nodes
you can create and manage any network user from the pricipal node(management node where 4760 Licence is decalred) or from other nodes if well done
Return to “X25”
