I had the same problem by a customer.
05/11 15:06:08 000001M|--/--/-/---|=1:1661=Monitel: Lack of vital resource, type 2
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 9 per cent
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 8 per cent
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 7 per cent
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 6 per cent
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 5 per cent
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 4 per cent
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 3 per cent
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 2 per cent
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 1 per cent
04/05/11 15:06:09 000001M|--/--/-/---|=3:1663=Monitel. Rate of free type 5 resources below to 0 per cent
04/05/11 15:06:20 000001M|--/--/-/---|=1:2077=CPU was halted due to a shutdown
But between incident 1663 and 2077 I had a ION error.
I think that the cp went down because of a problem with the internal ion. I replaced the cpu and after that everything was fine.
oxe restart
Re: oxe restart
Could be a dimensioning issue. Check your OPS. The issue is 99% not related to your CPU hardware.
And the ION error is the result, not the reason I thnik.
Have you checked the exceptions (excvisu)?
fabibogo
Re: oxe restart
I have a similar problem:
when I run the command oldincvisu -1 shows:
02/10/12 08:30:17 000001M|---/--/-/---|=0:1680=Monitel: Applicative error 5 type, infos 8480, 4
02/10/12 08:30:17 000001M|001/07/-/---|=4:3580=remove TEI: mod ISDN UNSOLICITED_UA (F=1) (0) realy:0 info:0
02/10/12 08:30:19 000001M|---/--/-/---|=3:4031=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:30:25 000001M|---/--/-/---|=3:4031x002=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:30:25 000001M|004/00/0/058|=3:0386=Sig. on IP set: No response from de set 20:d6:37:2f:1e:81,458
02/10/12 08:30:27 000001M|004/00/0/124|=4:0382=Init of IP set: No response from de set da:a1:e2:33:9b:2d,606
02/10/12 08:30:31 000001M|004/00/0/062|=5:2053=Terminal 62 in service
02/10/12 08:30:47 000001M|004/00/0/138|=3:0386=Sig. on IP set: No response from de set 2f:c3:04:6b:34:73,256
02/10/12 08:30:48 000001M|004/00/0/117|=3:0386=Sig. on IP set: No response from de set ec:c2:f3:c7:7a:aa,733
02/10/12 08:30:50 000001M|---/--/-/---|=3:4031=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:31:14 000001M|---/--/-/---|=3:4031x002=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:31:14 000001M|004/00/0/138|=5:2053=Terminal 138 in service
02/10/12 08:31:15 000001M|004/00/0/117|=5:2053=Terminal 117 in service
02/10/12 08:31:19 000001M|004/00/0/068|=5:2053=Terminal 68 in service
02/10/12 08:31:20 000001M|---/--/-/---|=3:4031=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:31:26 000001M|---/--/-/---|=3:4031x002=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:31:26 000001M|004/00/0/129|=5:2053=Terminal 129 in service
02/10/12 08:31:28 000001M|004/00/0/124|=4:0382=Init of IP set: No response from de set da:a1:e2:33:9b:2d,606
02/10/12 08:31:42 000001M|004/00/0/105|=5:2053=Terminal 105 in service
02/10/12 08:31:50 000001M|---/--/-/---|=3:4031=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:31:51 000001M|004/00/0/115|=5:2053=Terminal 115 in service
02/10/12 08:31:55 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
02/10/12 08:31:59 000001M|---/--/-/---|=3:4031=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:32:10 000001M|---/--/-/---|=3:4031=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:32:10 000001M|004/00/0/080|=4:0382=Init of IP set: No response from de set bb:8f:cf:2d:13:5b,427
02/10/12 08:32:20 000001M|---/--/-/---|=3:4031=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:32:25 000001M|---/--/-/---|=3:4031x002=CSTA : VAD DTO -> no free physical DSP equipment
02/10/12 08:32:25 000001M|---/--/-/---|=1:2073=Shutdown command has been called
02/10/12 08:32:28 000001M|004/00/0/124|=4:0382=Init of IP set: No response from de set da:a1:e2:33:9b:2d,606
02/10/12 08:32:28 000001M|---/--/-/---|=1:2077=CPU was halted due to a shutdown
02/10/12 08:32:30 000001M|000/28/-/---|=0:0416=Too long Restart for IPLINK
02/10/12 08:32:38 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli BROADCAST oper 18 err 15
02/10/12 08:32:38 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli EVENTMON oper 28 err -10
02/10/12 08:32:38 000001M|---/--/-/---|=3:4076=PBM : signal 15 caught
02/10/12 08:32:38 000001M|---/--/-/---|=3:4019=CSTA server : 3840 exit
02/10/12 08:32:40 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli ASCII : feature incident 20 15
02/10/12 08:32:40 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 20 15
02/10/12 08:32:40 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACC_ETH oper 20 err 15
02/10/12 08:32:40 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli PRINTING : feature incident 20 15
02/10/12 08:32:40 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli SAVE oper 20 err 15
fabibogo
Re: oxe restart
and when I run the command oldincvisu -2 shows:
03/09/12 13:03:34 000001M|001/00/-/---|=0:4403=Error 8 on message type 3 on timeslot 92
03/09/12 13:03:56 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
03/09/12 13:04:11 000001M|005/04/0/000|=4:2113=T2 lapD not established still trying
03/09/12 13:04:14 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
03/09/12 13:04:15 000001M|003/06/0/000|=4:2113=T2 lapD not established still trying
03/09/12 13:04:21 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
03/09/12 13:04:23 000001M|005/04/0/000|=4:2113=T2 lapD not established still trying
03/09/12 13:04:23 000001M|005/04/0/000|=5:0311=T2 Dlap Established
03/09/12 13:04:25 000001M|003/06/0/000|=4:2113=T2 lapD not established still trying
03/09/12 13:04:25 000001M|003/06/0/000|=5:0311=T2 Dlap Established
03/09/12 13:04:41 000001M|005/04/-/---|=5:2019=PRA coupler commissioning
03/09/12 13:04:44 000001M|004/00/0/089|=5:2053=Terminal 89 in service
03/09/12 13:04:45 000001M|003/06/-/---|=5:2019=PRA coupler commissioning
03/09/12 13:04:53 000001M|---/--/-/---|=1:2073=Shutdown command has been called
03/09/12 13:04:56 000001M|---/--/-/---|=1:2077=CPU was halted due to a shutdown
03/09/12 13:04:57 000001M|000/28/-/---|=0:0416=Too long Restart for IPLINK
03/09/12 13:05:05 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli BROADCAST oper 18 err 15
03/09/12 13:05:05 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli EVENTMON oper 28 err -10
03/09/12 13:05:05 000001M|---/--/-/---|=3:4076=PBM : signal 15 caught
03/09/12 13:05:05 000001M|---/--/-/---|=3:4019=CSTA server : 3840 exit
03/09/12 13:05:07 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli ASCII : feature incident 20 15
03/09/12 13:05:07 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 20 15
03/09/12 13:05:07 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACC_ETH oper 20 err 15
03/09/12 13:05:07 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli PRINTING : feature incident 20 15
03/09/12 13:05:07 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli SAVE oper 20 err 15
can anyone help?
can anyone help?
Re: oxe restart
>can anyone help?
Not with these infos.
