Root Cause “why is RTI-Connector not connecting”
• 3 x NIC RAS & Routing Service activated (used because I simulated the customers Network)
Bad issue RTI-Connector is not connecting to WBM
######################### following error message in RTI log ##################################################
2012-09-26 23:05:19 : adding statistic names used to get configuration and Agent object type
2012-09-26 23:05:20 : Socket Error : [10061]:Connection is forcefully rejected... retrying to connect to WBM...
2012-09-26 23:05:20 : Disconnecting from soft panel manager
• 1. attempt to solve the bad issue
o stopping only the RAS & RAS & Routing Service
restart of RTI service and Softpanel service
--without success same issue
• 2. attempt to solve the bad issue
o RAS & RAS & Routing Service is still stopped
o Shutdown of win 2008 Server
Deletion of 1 Routing interface (now I VM has 2x NIC)
start of Server an testing
same issue …without success
• 3. attempt to solve the bad issue
o RAS & RAS & Routing Service is still stopped it’s not possible to start that Service because of only one Interface
Deletion of all Routing interface (now only 1xNIC is left…like in productive use)
• 4. Reinstall of SoftpanelManager & RTI Server
o 1. SPM installation
o 2. RTI Server installation
o 3. like in Dokumentation “Error # 429: ActiveX component can't create object“ appear
o 4. copy running “ccs.ini” --> c:\Windows\SysWOW64\config\systemprofile\AppData\Local\Alcatel\CCSupervisor
even without restart of RTI Service …
So end is good all is good! Everything is running perfectly!
ross
@krzysioD
rticonnector.ini was not the problem, i tried already "localhost" and "ipAdress"
no filters was set... "*"
Alcatel Support guy "Mikael" wasvery friendly, tested with me about 3 hour in my VM-LAB, he was very good in SPM but also wondering because that issue
Later we did the installation togehter in productive evironment there we had only 1NIC, so the installation was done in 10 minutes!
