Connection problems...
grabb
Re: Connection problems...
Post by grabb »
just check the file parameters.txt under C:\Alcatel\OmniPCXTSA\dyn\otuc@3595\cfg (/opt/... for linux)
you can find a parameter login where the hostname of your otuc-server is listed. if there is only the hostname, then after update you will login against this host and your client may not resolve dns-name, try to use the fqdn
here is an example, instead of names you can use the ip-address
[MYPHONE]
license_server_host 10.10.10.88
license_server_port 27000
license_file alcotuc.lic
url_unified_login 10.10.10.88:443
url_webphonesetprogramming
ACSE OTUC
ACSEOXE
alf
Post by alf »
The connection problems are solved!
Now the OTUC Server is global in the "not use proxy" list ;)
thanks for help!
Alf
? but that is a basic setting...
Have you took the training?
alf
Post by alf »
i was only on a administration, not an installation training in stuttgart.
Alf
MasterB
Post by MasterB »
Hey,
check on the OTUC/webAdmin if you can see the login of the User (via GUI) in the Authentification/menu.
Return to “GENERAL”
