hello,
your answer is a bit worrying is what I do little to solve the problem with this version
and if I want to upgrade to the latest version, this is you have a solution?
thank you for your support
Sync problem with pabx via remote link T2
youfo007
Re: Sync problem with pabx via remote link T2
hello,
your answer is a bit worrying, is that I can not solve the problem with the existing patch?
how can I install the new patch?
thank you
thank you
I remember such a bug (no external synchro even it was configured on NPRAE access) in R7.1 version
So you'd better have latest SW loaded and tested for this problem as 1st step.
youfo007
I thank yours to everyone.
I think I found a solution to this prob sync
I configured port switch and converter E1/IP in 100 Mbit / s Full Duplex to cancel the auto-negotiation on Ethernet, because when you do you are in autonegotiation on port 100MBit / s Full duplex and the other port you find 100MBit / s half duplex, and it raises the prob timing.
Good luck to everyone
