Here are the screenshots about the RP in the OT (I hope this is the correct menu to do it...)
And the other one is the error message after I try to associate the mobile to the user.
In the Reverse Proxy the name is written manually, but the Application server is automatically filled in.
There isn't external reverse proxy, only the OT and 8770 on the LAN.
I haven't any documentation about the offsite mobility config, I didn't find it on the Alcatel Business partner.
On the training there was no information and practise about this.
BR,
Balint
Android client
baalynt
Re: Android client
corwin
Re: Android client
Complete your RP fields with for all empty parameters https:// opentouch FQDN
Then thé public URL Will same as privante URL and association Will be allowed
If you CAN create service request you should ask for automatic setup of RP with public URL = privante URL
So the basic setup without real RP and usage in wifi entreprise Will work without any particular setup on RP parameter of ot
baalynt
Re: Android client
Yesss!
It works! Thank you very much! This was the problem.
And I have one more question. When I have a user, No. 220. It has got a 8082 user, with No. 221, and a new
Android phone, No. 222.
When I call directly the 221 or 222 set number, it rings. But when I call 220 as User, the 8082 rings, but don't go forward t mobile.
I hear a voice, that press 5 to callback. Where can I configure the sequence of ringing, and why dont't go to mobile when call 220?
Thanks a lot, Balint
corwin
Re: Android client
Ringing séquence is called multi device routing
All device registered CAN be included or excluded from the ringing list
From vhe, press on the user avatar picture
Then routing
My office phone / all business phone is the default ringing profile, you CAN also select custom and ensable disable one device
Or create from myIC Pc a routing profile to save your preferences
Normally , nobody calll device number
Only user number should be called
Finally
On user and on each device you have a Max Line quantity
When reached, your caller will get the Proposal of call Back : dial 5 because user is busy
Use the URL https:// otfqdn to access thé end user profile page and up date your Max Line that trigger the busy state
Call back also happens on NO answer, if no overflow defined....
Of course if ghost com is active, user may be permanently busy
If you have à demo server, reboot Opentouch
And take care to put offsite mobility licence on the OT user, this allow routing to mobile.....
Then routing
Finally
