@devnull. and @slixxboy..
thanks for your kind reply..
@slixxboy .. the all ports were activated for PoE. the issue was not related to that..
.@devnull. as you said, i disabaled lanpower 1 capacitor-detection.. and it works fine after this.. all ports are throwing PoE..
@all.. thanks for participating to solve this issue. and help appreciated .. may god bless you all.
musthafa habeeb
LANPOWER ISSUE ON 6850P
mhrahmanpt
Re: LANPOWER ISSUE ON 6850P
@slixxboy..
thansk for you reply..you are generous.. the all ports were acitvated alrady , so the issue was not related to port activation. it works fine after diableing landpower 1 capacitor -detection ... we need only lanpower 1 start for Enabling poe for Aruba AP. now all port are throwing PoE.
@devnull.. i tried after disabled " landpower 1 capacitor detection ..as you suggested in yoru previous reply.. now all ports are working. thanks devnull for your help..
@all. thanks for participating in this discuss to solve the issue.. its appreciates.. may allah bless you all.
mhrahmanpt
here confirm that there is a chance of not delivering PoE to Aruab AP's if you have enabled " landpower <stack number> capacitor-detection enable " ..
single command of landpower start <stack num> is enought to deliver to Aruba AP105..
thanks all. and appreciated all of your support to sort out this issue...
let me conclude here that , know issue on lanpower.
1:min 360w is requried to get poe from 6850p switch... 126 w power supply is not sufficient as it is just stanadard power supply.
2:no need of commnad "capcitor detection " but just start power based on stack number..
thanks..
thanks..
