I just recieved the faulty GD card and perform some tests.
At the first boot, I get this unknown menu. This seems to come from the RAM regarding to the following log :
*** BIOS Version 3EH30227ALAC bios100/011.003 ***
*** Generated on Dec/16/2008 at 11:27 ***
memory test started lng=133169152 with 0
memory test fail at 4000000h for running flash(soldered=1 socket=0)=1,BIOScase:4,BIOSv24:0,verrou=1,algoNOR=1,size=1,base=3FF80000
DIMM characteristics->: JEDEC Manu ID:ê,......
Memory type(EDO,FPM..):0x 4
# of row address:13
# of col address 9
# of module row 1
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI:scan_bus for bus 0
PCI:bus=00h,devfn=00h ,[vendor:device]=[1022h/3000h]
PCI:bus=00h,devfn=60h ,[vendor:device]=[100Bh/0020h]
PCI:bus=00h,devfn=98h ,[vendor:device]=[1064h/2101h]
PCI:scan_buses with 00h secondary buses
PCI:command = 3FFH for device 00:00
PCI: Assigning I/O space FC00-FCFF for 00:60 BAR= 10
PCI:Assign memory space BFFFF000H to BFFFFFFFH for device 00:60
PCI:command = 3FFH for device 00:60
PCI:Assign memory space BFFFD000H to BFFFDFFFH for device 00:98
PCI: Assigning I/O space FD00-FD1F for 00:98 BAR= 14
PCI: Unable to handle I/O allocation for 00:98 (FF04) BAR= 18
PCI:command = 3FFH for device 00:98
assigning irq10 to xchange
B0 = 17
DRCTMCTL = 1E
DRCCTL = 8
DBCTL = 11
Set external RTC
Set Internal RTC
No external RTC detected
gpbus sig timing : 0-2-1-2-1-2!
CMOS is available
Xchange PCI mem base OK: 0,mbx= BFFFD000
dsp_accesses.stat_ctrl= FD00
Xchange PCI IO base OK: 0
Xchange irq OK: A
PCI command read for natsemi : 347
PCI Master Bit Setting...
pci_command set to: 357
0 80 9F 89 FD 4 ,IRQ 12.on interrupt pin:2
eth0: Transceiver status 0x 7849 advertising 5E1
Flashfx version:800.004
Found LS mode on Main
NAND Flash Configuration:
CPU size : 128 MBytes
free spare blocks: 37
NAND Flash Details:
chip #0 : Type=NAND01GW3B Id=20F1H Size=128(MBytes) Unit size=131072 Page Size=2048
time :sec= 6,min= 5,hour=14,DoW= 6,date=22,Month=11,year=13
time :sec= 9,min= 5,hour=14,DoW= 6,date=22,Month=11,year=13
ALIZE informations :
Memory Detected : 131072 Ko
Flash Detected
DaughterBoard Not Detected
XCHANGE Detected
XCHANGE Chip Initialization OK
Ethernet Found : 1
Ethernet Chip Initialization OK
Hard Disk Not Detected
PCM11 selected
CPU at 133 mhz
check lock RTC
!!!ERROR !! Abnormal Board configuration
Alize BIOS Monitor
Monitor Main Menu :
1 - CMOS Management
2 - Clock Management
3 - Memory & IO monitor
4 - Device monitor
5 - Flash Programming
6 - NMI Management
7 - Force CPU at 133mhz
8 - Load system
9 - Memory extended tests
10 - Change the environnment type(client,factory,validation)
11 - After load files comparison
12 - Compute PAR registers
13 - Compute PAR register then program it
14 - Set reset Write buffer
15 - Force CPU at 100mhz
16 - Reset system
17 - Disable watch dog
18 - Enable watch dog
19 - Switch console
?I replace the RAM by an other one, the card booted correctly.
Then, I put back the faulty RAM and it worked correcly.
I also tried to put the faulty RAM in a working GD and it worked correctly.
Very strange issue...
M.B.
