Dear Vad,
Yes in OXE I am reciving 4470550057602 from cisco where 447 is the PCM TG seizing prefix and the NPD of both T2 and And PCM is 3 and the DID transcoding Called DID as well as Calling DID are "0" as "0" is the DID translator I am using
using PCM trunks for DID/DOD via ISDN link
Re: using PCM trunks for DID/DOD via ISDN link
Use for test in T2 TG - NPD without DID transcoding (called DID=-1).
Xero
Called DID will be for incoming call, and I have no problem with incoming call. Should I do the test for called DID or Calling DID (outgoing)?
Called DID - for incoming calls. You receive from T2 (Cisco) - 4470550057602 - and want to establish transit connection. I think you cannot manage DID rules for such connections.
When you receive digits from Cisco - I think you need to use T2 TG without DID transcoding.
use pcm and mfR2 traces
performe those traces and see who is calling if the cisco extension it should be transcoded as pcm did config .
second test put trancoding under t2 trunk (between oxe and cisco ) to -1 no did/dod transcoding and redo the test .
tuner km
tuner ctr
actdg all=off
trc i
tuner appli-trace=on
actdbg mf=on
mtracer -a
tuner km
tuner ctr
actdg all=off
trc i
actdbg mf=on
mtracer -a
