MIC Mobile - Configuration error
Split
Re: MIC Mobile - Configuration error
I am not sure if mic 8600 v3 is compatible with otbe... whats your aim
lapepe
I have this configuration at the customer...
OTMS User with Standart IP A4038 device in OXE and with twin set Remote Extension (Android with MIC).
Split
If i understand right you configure a remote extension in the oxe and set it as Tandem to the 4038 and the 4038 is the Main Set
So a SSH to the server, go the ICS installation path and you will find a sh script to disable ssl. Just run it.
lapepe
To Split....
Yes, you understand me OK.
To Cavagnaro...
Which ssh script (the list is attached)?
To Cavagnaro...
Seems they removed a lot of scripts...sorry no clue then how to do it
Split
Re: AW: MIC Mobile - Configuration error
Ok i check tc and lapepe you are right 8600 v3 must be used for your configuration for a standard userSplit wrote:I am not sure if mic 8600 v3 is compatible with otbe... whats your aim
No idea where you can disable ssl use Google and search for wireshark and ssl there are a few tutorials how discrypting ssl with wireshark ..... may be it helps
lapepe
Hi all, i try install all fresh servers in our test lab now.
I have problem with install OMTS as Virtual Machine (test install to Oracle Virtual Box, VMware ESXi 5.5.0, VMware workstation 10).
I see always this error...
Error Parsing Kickstart Config
The following problem occurred on line 8 of the kickstart file:
Percentage must be between 0 and 100.
Any idea ??
EDIT: this problem resolved - enough to set the virtual disk capacity to 150 gigabytes.
I post news after installation and configuration fresh servers in our lab.
Any idea ??
lapepe
Hi all.
In my lab is same results as in customer installation
Today i had remote desktop support from india.
Whole trouble was in URL adress on Android application !!!
No only..
But we must ...
[/color]
Uffff, a lot of hard work for such a stupid problem.
King regard, LaPEPE
No only..
https://NameOfTheServerCode: Select all
https://NameOfTheServer/DMUffff, a lot of hard work for such a stupid problem.
King regard, LaPEPE
