ISDN REQUESTED CIRCUIT NOT AVAILABLE
mokhtar ACFE
Re: ISDN REQUESTED CIRCUIT NOT AVAILABLE
Post by mokhtar ACFE »
thanks Haroun ,
i have tow trunk in my pbx selta installation one Qsig and the second is in ISDN wich i try to manage it in order to route externel PCM R2 call . because as you know we coudl not trnsmit via qsig the installation number 02999 .
i will to try with bloc mode .
hi i have check with your colleague and it was that number of digit to send was zero change it to 29 and he was able to call selta users
no need to manager installation number at selta pbx , because it should be done by the oxe where pcmr2 trunk is connected to .
btw reverse ddi is not done at all on the oxe for selta why your 're getting this worng clip ?
the question is why ddi works for and reverse ddi didnot .
open new topic and post call trace form selta to PSTN using pcmr2 via oxe.
put isdn trace for qsig from selta to oxe and at sametime mfr2 signalling trace -use combined trace actdbg mfr=on isdn=on
mokhtar ACFE
htnaks ;
now i can call , the trunks are free . but when the call is established , I can not hear and the called does not hear me . just silence.
Can any one help me ?
Return to “Trunk Groups”
