SIP Congestion
Re: SIP Congestion
can you ping this adress 10.200.7.157 from oxe
stc is public provider no SBC in between?!
5060 is only for signaling , you should chek also after that rtp's @ & ports
Re: SIP Congestion
As there is not basic 200 OK from INVITE, no reason to dig yet on RTP ports haroun ;)
First he must check the handshake
Re: SIP Congestion
ofcorse cav ,once if he resolve the signaling path , he must just after check the rtp one , i suspect he will got an issue at rtp, but hope i'm wrong
Re: SIP Congestion
Well he has all tips and evidence on his hands, lets see what (if) he answers back
ranjithvkumar
Re: SIP Congestion
Post by ranjithvkumar »
Hello Experts,
there was some routing issue in firewall configuration. Now SIP packets are exchanged between the servers but i am not able to make & receive calls. I have attached level 3 traces.
My internal number is 100313 (example number) and number given by service provider is 0165299200. I did DID for incoming call but its not working. Service provider says that i am sending my internal number to them that's y they are getting " 484 Address Incomplete" error message when i am making outgoing calls.
Re: SIP Congestion
hi
and the did validate at sip trunkg ?
your logs are duplicted and are for incoming calls ; response code is 404 not found so i think did is not working at al l that 'why SP say they see extension instead of installation number+did in the outgoing
btw i see sbc "s=SBC call" ?:-)
ranjithvkumar
Re: SIP Congestion
Hi Haroun,
Sorry for duplicate file. Now i have attached the outgoing logs.
Yes i believe DID is not working. Can you please let me know what are the parameters i need to touch. So that i can cross verify. Plz help me on this.
Thanks.
Re: SIP Congestion
validate did transcoding at global parameter of trunk group
─Consultation/Modification: Faisceaux─────────────────────────────────────────┐
│ Faisceau privé + Non │
│ Variante signalisation Q931 + ABC-F │
│ Variante signalisation SS7 + Aucune │
│ Nombre chiffres à émettre : 29 │
│ Type sélection canaux + Quantité │
│ um.Q23 auto.sur appel sortant + Non │
│ Spécificité T2 + SIP │
│ seau homogéne pour RTP direct + Non │
│ Catégorie accès rés.public : 31 │
Transcodage SDA + Oui
│ Accepte SUU dans le SETUP + Oui │
│ Priorité implicite │
│ Mode activation : 0 │
│ Niveau de priorité : 0 │
│ Préemptable + Non │
│ restriction d'appels entrants : 10 │
│ restriction d'appels sortants : 10 │
afater validating this paremetre go down in hirearchy numbering plan descriptor
exemple
─Consultation/Modification: Sélecteur de Plan de Num Faisceau─┐
│ No noeud-réseau (réservé soft) : 1 │
│ No faisceau : 1801 │
│ Instance (réservée soft) : 1 │
│ No Desc.Plan.Num public : 36 │
│ No Desc.Plan.Num privé : 36 │
│ Mode de gestion + Normal │
AND SEE what havebeen automaticly assigned and manage this npd according to sp ans rom ther you can select did rule orput full installation number
some commande to check :didtest
ranjithvkumar
Re: SIP Congestion
Can you please send me in English?
Thanks.
Re: SIP Congestion
note those parameters are for my config
HERE NO did needed
┌─Consult/Modify: Trunk Groups─────────────────────────────────────────────────┐
│ Private Trunk Group + False │
│ Q931 signal variant + ABC-F │
│ SS7 signal variant + No variant │
│ Number Of Digits To Send : 29 │
│ Channel selection type + Quantum │
│ DTMF dialing on outgoing call + NO │
│ T2 Specificity + SIP │
│ genous network for direct RTP + NO │
│ Public Network Category : 31 │
│ DDI transcoding + True │
│ Can support UUS in SETUP + True │
│ Implicit Priority │
│ Activation mode : 0 │
│ Priority Level : 0 │
│ Preempter + NO │
│ ming calls Restriction categ. : 10 │
│ oing calls Restriction categ. : 10
┌─Consult/Modify: Trunk Group NPD Selector───────────┐
│ Trunk Group Id : 1801 │
│ Instance (reserved) : 1 │
│ Public NPD id : ..Consult/Mo │
│ Private NPD id : 36 │
│ Management Mode + Normal │
┌─Consult/Modify: Numbering Plan Description (NPD)─────────────────────┐
│ Description identifier : 36 │
│ Name : ..sip │
│ Calling Numbering plan ident. + NPI/TON Private Specific Number │
│ Called numbering plan ident. + NPI/TON Private Specific Number │
│ Authorize personal calling num use + False │
│ Install. number source + None used │
│ Default number source + None used │
│ Called DID identifier : -1 │
│ Calling/Connected DID identifier : -1 │
AS TOU SEE there is no did used ,identifier =-1
FOR OTHER EXEMPLE WERE DID IS MANAGED:
this one isdn all countries with no installation number -installation number is constructed at sp side he needs only the did
│ Q931 signal variant + ISDN all countries │
│ Channel selection type + Channel No by Channel No. │
│ DTMF dialing on outgoing call + YES │
│ T2 Specificity + None │
│ Public Network Category : 0 │
│ Preempter + NO │
│ oing calls Restriction categ. : 10 │
│ mpt1343 callee number + NO
│ Trunk Group Id : 123 │
│ Public NPD id : 1 │
│ Private NPD id : 1 │
│ Management Mode + Expert
│ Description identifier : 1 │
│ Name : U_U_N_N_DDI │
│ Calling Numbering plan ident. + Unknown │
│ Called numbering plan ident. + Unknown │
│ Called DID identifier : 1 │
│ Calling/Connected DID identifier : 1
┌─Consult/Modify: DDI number translator rules──────────────────────────┐
│ DDI num. transl. identifier : 1 │
│ First External Number : 165 │
│ First Internal Number : 51009 │
│ Range Size : 1 │
│ Unique Internal Number + NO │
here full number constructed at my side, sp needs to see the whole number
│ Transcom Trunk Group + False │
│ Auto.reserv.by Attendant + False │
│ Overflow trunk group No. : -1 │
│ Tone on seizure + False │
│ Prefix Sending + False │
│ Register Signalling + MF R2 │
│ Preempter + NO │
│ Description identifier : 35 │
│ Name : Haroun_Telcom │
│ Calling Numbering plan ident. + NPI/TON Isdn National │
│ Called numbering plan ident. + NPI/TON Isdn National │
│ Authorize personal calling num use + True │
│ Install. number source + NPD source │
│ Default number source + NPD source │
│ Called DID identifier : 2 │
│ Calling/Connected DID identifier : 2 │
│ Installation number : 03898 │
│ Default number( num. inst. sup.) : 2020
│ DDI num. transl. identifier : 2 │
│ First External Number : 2000 │
│ Range Size : 1 │
Return to “SIP”
