If I write "APPLICATION_TYPE=APPL_SIP" into the lanpbx file the log looks like this:
<15> 00:00:07 000-00:00:07.640 INIT : LANPBX: APPLICATION_TYPE=APPL_SIP ignored 192.168.2.180 22/12 17:27:23.795
<15> 00:00:07 000-00:00:07.640 INIT : found 0/0 CS line(s) in lanpbx 192.168.2.180 22/12 17:27:23.795
<15> 00:00:07 000-00:00:07.640 MGR : mgr_startup: init status 3.25 bad file content 192.168.2.180 22/12 17:27:23.795
<15> 00:00:07 000-00:00:07.640 INIT : ############ msg_event_init_status 192.168.2.180 22/12 17:27:23.795
<15> 00:00:07 000-00:00:07.640 INIT : ###########step_initscreen:bad file content 192.168.2.180 22/12 17:27:23.795
<15> 00:00:07 000-00:00:07.640 INIT : ###########step_initscreen,step:3 192.168.2.180 22/12 17:27:23.795
<15> 00:00:11 000-00:00:11.640 MGR : mgr_startup: init status 3.02 failed 192.168.2.180 22/12 17:27:27.837
<15> 00:00:11 000-00:00:11.640 INIT : CODE binary is invalid -> force download 192.168.2.180 22/12 17:27:27.838
<15> 00:00:11 000-00:00:11.640 MGR : mgr_startup: init status 4.00 started 192.168.2.180 22/12 17:27:27.838
<15> 00:00:11 000-00:00:11.640 INIT : ############ msg_event_init_status 192.168.2.180 22/12 17:27:27.839
<15> 00:00:11 000-00:00:11.640 INIT : ###########step_initscreen:failed 192.168.2.180 22/12 17:27:27.839
<15> 00:00:11 000-00:00:11.640 INIT : ###########step_initscreen,step:3 192.168.2.180 22/12 17:27:27.840
<15> 00:00:11 000-00:00:11.660 INIT : ############ msg_event_init_status 192.168.2.180 22/12 17:27:27.840
<15> 00:00:11 000-00:00:11.660 INIT : ###########step_initscreen:4/5 binary download 192.168.2.180 22/12 17:27:27.841
<15> 00:00:11 000-00:00:11.660 INIT : ###########step_initscreen,step:4 192.168.2.180 22/12 17:27:27.842
<15> 00:00:13 000-00:00:13.640 MGR : mgr_startup: init status 4.38 getting code 192.168.2.180 22/12 17:27:29.781
<15> 00:00:13 000-00:00:13.640 INIT : ############ msg_event_init_status 192.168.2.180 22/12 17:27:29.781
<15> 00:00:13 000-00:00:13.640 INIT : ###########step_initscreen:getting code 192.168.2.180 22/12 17:27:29.781
<15> 00:00:13 000-00:00:13.640 INIT : ###########step_initscreen,step:4 192.168.2.180 22/12 17:27:29.781
<15> 00:00:15 000-00:00:15.640 INIT : dhs3_get_xxxx: tftp://192.168.2.110:69/noe4018 192.168.2.180 22/12 17:27:31.756
<15> 00:00:15 000-00:00:15.640 TFTP : canditate server 192.168.2.110 / requesting noe4018-header 192.168.2.180 22/12 17:27:31.771
<15> 00:00:15 000-00:00:15.640 TFTP : elected server is 192.168.2.110 192.168.2.180 22/12 17:27:31.787
<15> 00:00:15 000-00:00:15.640 TFTP : recv( 1): 19 ERR(1:File not found) 192.168.2.180 22/12 17:27:31.787
<15> 00:00:15 000-00:00:15.640 TFTP : canditate server 192.168.2.110 / requesting noe4018 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.640 TFTP : elected server is 192.168.2.110 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.640 TFTP : option: timeout 5 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.640 TFTP : option: blksize 1428 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.640 TFTP : option: tsize 1956527 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.640 TFTP : xfer started 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.640 TFTP : free memory = 4744000 bytes 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.650 INIT : __update_do_check: version 21110 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.650 INIT : flash not supported in V21110 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.650 TFTP : xmit( 1): 20 ERR(0:Abort transfer.) 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.650 MGR : mgr_startup: init status 4.36 not compatible 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.650 INIT : ############ msg_event_init_status 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.650 INIT : ###########step_initscreen:not compatible 192.168.2.180 22/12 17:27:31.802
<15> 00:00:15 000-00:00:15.650 INIT : ###########step_initscreen,step:4 192.168.2.180 22/12 17:27:31.802
<15> 00:00:17 000-00:00:17.650 MGR : mgr_startup: init status 4.50 getting load 192.168.2.180 22/12 17:27:33.789
<15> 00:00:17 000-00:00:17.650 INIT : ############ msg_event_init_status 192.168.2.180 22/12 17:27:33.789
<15> 00:00:17 000-00:00:17.650 INIT : ###########step_initscreen:getting load 192.168.2.180 22/12 17:27:33.789
<15> 00:00:17 000-00:00:17.650 INIT : ###########step_initscreen,step:4 192.168.2.180 22/12 17:27:33.789
<15> 00:00:19 000-00:00:19.650 INIT : dhs3_get_xxxx: tftp://192.168.2.110:69/bin4018 192.168.2.180 22/12 17:27:36.081
<15> 00:00:19 000-00:00:19.650 TFTP : canditate server 192.168.2.110 / requesting bin4018-header 192.168.2.180 22/12 17:27:36.081
<15> 00:00:19 000-00:00:19.650 TFTP : elected server is 192.168.2.110 192.168.2.180 22/12 17:27:36.081
<15> 00:00:19 000-00:00:19.650 TFTP : recv( 1): 19 ERR(1:File not found) 192.168.2.180 22/12 17:27:36.081
<15> 00:00:19 000-00:00:19.650 TFTP : canditate server 192.168.2.110 / requesting bin4018 192.168.2.180 22/12 17:27:36.081
<15> 00:00:19 000-00:00:19.650 TFTP : option: timeout 5 192.168.2.180 22/12 17:27:36.081
<15> 00:00:19 000-00:00:19.650 TFTP : option: blksize 1428 192.168.2.180 22/12 17:27:36.081
<15> 00:00:19 000-00:00:19.650 TFTP : option: tsize 863417 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.650 TFTP : xfer started 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.650 TFTP : free memory = 4744000 bytes 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.650 INIT : __update_do_check: version 43180 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.650 BCOMPAT: binary is compatible 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.930 INIT : binary_checksum_bank 0: OK 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.930 INIT : binary_checksum_bank 1: bad header 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.930 INIT : cannot update - no rescue binary 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.930 TFTP : xmit( 1): 20 ERR(0:Abort transfer.) 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.930 MGR : mgr_startup: init status 4.51 no rescue binary 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.930 INIT : ############ msg_event_init_status 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.930 INIT : ###########step_initscreen:no rescue binary 192.168.2.180 22/12 17:27:36.097
<15> 00:00:19 000-00:00:19.940 INIT : ###########step_initscreen,step:4 192.168.2.180 22/12 17:27:36.097
<15> 00:00:21 000-00:00:21.930 INIT : binary_checksum_bank 1: bad header 192.168.2.180 22/12 17:27:38.368
<15> 00:00:21 000-00:00:21.930 binary_switch: unable to switch (invalid) 192.168.2.180 22/12 17:27:38.383
<15> 00:00:21 000-00:00:21.930 DEFENCE: reset__: [27] bootloader_end_job [H] (694 tskinit.c) 192.168.2.180 22/12 17:27:38.383
