Some IP touch 4028/38 not working tftp no response
fery_s
Re: Some IP touch 4028/38 not working tftp no response
Post by fery_s »
you can get binay files from call server (/usr2/downbin/) with ftp and put it in external tftp server(like tftpd program).
just one more try lanpbxbuild -auto.
jgaadesh
Post by jgaadesh »
Hi.. Fery again tried lanpbxbuild -auto but issue remains same
fery_s
Post by fery_s »
can you test the phone on the other release? and is the strict vlan status same as the others phone?
tgn
Post by tgn »
there are possible issues (no tftp response) with desktop sharing feature and upgraded databases. check free seating switch in phone set ip-parameters (at the end of the list) and set this to false if present. there is also a knowledgebase article about this (but i didn't remember the article number).
regards...
--- back to basics... focus your eyes on the essential things... ---
jgaadesh
Post by jgaadesh »
hi tgn,
Where we get this free seating switch option ,its on the phone configuration phone menu?
also users which is Out of service is not an DS users..
tgn
Post by tgn »
thers is a point called "free seating" in ip parameters (the menu which you'll reach with i+# on the phone), whenever a desksharing user is logged on a desksharing set. it's stored local in the ip-phone's flash memory (not in the callserver database.)
regards...
murraya
Post by murraya »
another silly thought, spare ip addresses in scope?
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
jgaadesh
Post by jgaadesh »
hi tgn,
This issue is related normal extension not an DSS users so we checked the extension & can't found any free seating option in the phone configuration menu(i+#).
sadim
Post by sadim »
Can you take a tcp/ip capture on CS and on the set at same time
jgaadesh
Post by jgaadesh »
Does anybody know detailed description about how to upgrade of firmware version of 4028/38 with using tftpd server...
there are chance the ip phones flash is corrupted..
i already tried to upload the /usr2/downbin files to tftpd server but its not working pls help.
Return to “MAIN”
