Cannot access to ISDN trunk OXE
mrbi1310
Re: Cannot access to ISDN trunk OXE
Post by mrbi1310 »
The issue solved by service provider, they changed some parameter,
Thanks Vad
hnorbi
Post by hnorbi »
I have similar problem.
I connect an own Cisco device or Ericsson device with an OXE 8.0.1. The master is the Cisco side, the incoming calls works fine.
t3, tracer, mtrace logs are shows nothing.
I try to direkt trunk seizure.
In first I select the trunk, I get a tone, I can enter number, and a few seconds get the congestion message.
After this, when I select, I get immediately.
Number Compatible With : -1
Number Of Digits To Send : 4
| T R U N K S T A T E Trunk group number : 97 |
| Trunk group name : Cisco ISDN |
| Number of Trunks : 2 |
| Index : 1 2 |
| State : F F |
| T R U N K S T A T E - MIX44 Coupler Crystal_nbr = 3 |
| IN SERVICE Coupler Nbr = 2 |
| Access 0 Trunk Grp 97 97 Access 4 Trunk Grp |
| Type: .. State F F Type: State |
| Access 1 Trunk Grp 98 98 Access 5 Trunk Grp |
| Type: T0 State F F Type: State |
| Access 2 Trunk Grp Access 6 Trunk Grp |
| Type: .. State Type: State |
| Access 3 Trunk Grp Access 7 Trunk Grp |
What I missed?
Do you have some incidents when you try to make outgoing call?
hnorbi
Post by hnorbi »
I vad,
> incinfo
Choose language (help to list languages):
US0
Incident number (q to quit):
> incstart
New V24 port : stdout
> incvisu
14/10/18 02:42:00 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
14/10/18 07:12:00 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
14/10/18 09:53:50 000001M|---/--/-/---|=4:3077=NTP: Synchronization lost
14/10/18 11:42:00 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
14/10/18 12:44:54 000001M|---/--/-/---|=4:3077=NTP: Synchronization lost
14/10/18 16:12:00 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
14/10/18 20:42:00 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
15/10/18 01:12:00 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
15/10/18 05:42:00 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
15/10/18 10:12:00 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
15/10/18 14:42:00 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
15/10/18 15:43:26 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
15/10/18 15:51:09 000001M|003/02/0/001|=2:0239=Alarm level 1 or 2 TO/SO Eqt 846 info 1
15/10/18 15:54:39 000001M|003/02/0/000|=2:0239=Alarm level 1 or 2 TO/SO Eqt 837 info 1
15/10/18 16:35:34 000001M|---/--/-/---|=3:1702=Bad use of ISDN equipment 837
15/10/18 16:35:34 000001M|---/--/-/---|=3:1702=Bad use of ISDN equipment 838
15/10/18 16:35:44 000001M|003/02/0/000|=2:0239=Alarm level 1 or 2 TO/SO Eqt 839 info 0
15/10/18 19:27:21 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
15/10/18 23:57:21 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
16/10/18 04:27:21 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
16/10/18 08:57:21 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
16/10/18 12:49:25 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
16/10/18 13:01:53 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
16/10/18 13:03:52 000001M|002/02/0/000|=2:0239=Alarm level 1 or 2 TO/SO Eqt 479 info 1
16/10/18 13:10:35 000001M|002/02/0/001|=2:0239=Alarm level 1 or 2 TO/SO Eqt 488 info 1
16/10/18 13:45:50 000001M|003/02/0/000|=2:0239=Alarm level 1 or 2 TO/SO Eqt 837 info 1
16/10/18 14:56:15 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
16/10/18 15:02:17 000001M|---/--/-/---|=3:1700=Protocol error Q931, type 4, access no 7
16/10/18 15:02:23 000001M|---/--/-/---|=3:1700=Protocol error Q931, type 4, access no 7
16/10/18 15:02:53 000001M|---/--/-/---|=3:1700=Protocol error Q931, type 4, access no 7
16/10/18 15:02:53 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
16/10/18 15:05:22 000001M|003/02/0/000|=2:0239=Alarm level 1 or 2 TO/SO Eqt 837 info 1
16/10/18 15:05:30 000001M|---/--/-/---|=3:1700=Protocol error Q931, type 4, access no 7
16/10/18 15:06:00 000001M|---/--/-/---|=3:1700x002=Protocol error Q931, type 4, access no 7
16/10/18 15:16:50 000001M|003/02/0/000|=2:0239=Alarm level 1 or 2 TO/SO Eqt 837 info 1
16/10/18 15:40:58 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
16/10/18 15:54:01 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
16/10/18 16:32:29 000001M|---/--/-/---|=4:3077=NTP: Synchronization lost
16/10/18 17:03:44 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
16/10/18 21:33:43 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
17/10/18 00:39:24 000001M|---/--/-/---|=4:3077=NTP: Synchronization lost
17/10/18 01:43:34 000001M|---/--/-/---|=4:3077=NTP: Synchronization lost
17/10/18 02:03:43 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
17/10/18 06:33:43 000001M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
17/10/18 08:32:03 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
Level 2 activation failure on O/G call (t3 - trace for next level, level3).
4 : Wrong length of the call reference
1 - Synchronization priority managed or not (infocs command)?
2 - Try to make outgoing call when you have established incoming call (via the same access)
hnorbi
Post by hnorbi »
Hi Vad,
> infocs
Wed Oct 17 13:26:10 CEST 2018
| N_CR | N_CPL | TYPE | N_ACCES | PRIO | SYNC_CLOCK | TG/LK |
| Synchronization on global domain |
| Synchronization on domain no 2 |
| 2 | 6 | PRA T2 | 0 | 201 | NOT SYNC | TG:0 |
| 2 | 7 | PRA T2 | 0 | 202 | NOT SYNC | TG:0 |
| Warning domain no 2 is on free running |
+========================== Synchro DECT ==================================+
| N_CR | N_CPL | TYPE | DECT_CLOCK | Depending Crystals |
+========= campus synchronization via INTOFS ====================+
this node 1 is SLAVE of campus synchronization (master node = ?)
synchro = PHASE_NO_OPERATION (phase shift values = 0,0)
info1=0 info2=0 info3=0 info4=0
the call, I will try it
hnorbi
Post by hnorbi »
When I have an established incoming call, I also can not do an outgoung call
| (802333:000023) Physical-Event :
| long: 54 desti: 0 source: 0 cryst: 2 cpl: 10 us: 0 term: 0 type a7
| tei: 127 >>>> message received : SETUP [05] Call ref : 15
| IE:[18] CHANNEL (l=1) 89 -> T0/S0 : B1 channel exclusive
| IE:[1e] PROGRESS_ID (l=2) 81 83
| IE:[28] DISPLAY (l=8) `Phone 13`
| IE:[6c] CALLING_NUMBER (l=6) -> 00 80 Num : 4901
| IE:[70] CALLED_NUMBER (l=4) -> 80 Num : 202
| [a1] Sending complete
| (802333:000024) 1057: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 20 desti: 0 source: 15 cryst: 2 cpl: 10 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 95
| (802334:000025) 1057: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 21 desti: 0 source: 15 cryst: 2 cpl: 10 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 95
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (802340:000026) 1057: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 24 desti: 0 source: 15 cryst: 2 cpl: 10 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 95
| IE:[4c] CONNECTED_NUMBER (l=5) -> 01 81 Num : 202
| (802341:000027) Physical-Event :
| long: 17 desti: 0 source: 0 cryst: 2 cpl: 10 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 15
| (802404:000028) Physical-Event :
| long: 21 desti: 0 source: 0 cryst: 2 cpl: 10 us: 0 term: 0 type a5
| tei: 0 >>>> message received : DISCONNECT [45] Call ref : 15
| IE:[08] CAUSE (l=2) 82 90 -> [90] NORMAL CALL CLEARING
| (802404:000029) 1057: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : RELEASE [4d] Call ref : 95
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (802405:000030) Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 15
hnorbi
Post by hnorbi »
In ISDN port I can not set the sync, because is in the second cabinet.
hnorbi
Post by hnorbi »
I've got at the Cisco side:
Oct 17 14:46:21.906: ISDN L2_CODE: isdn_l2_process: TIMER_EVENT
Oct 17 14:46:21.906: ISDN L2_CODE: l2_timer()
Oct 17 14:46:21.906: ISDN Q921d: l2_timer: timer (0x4E3CED08), timer_type (0x1250)
Oct 17 14:46:21.906: ISDN BR0/3/0 L2_CODE: L2IF_GetDriverID()
Oct 17 14:46:21.906: ISDN BR0/3/0 PACKET: L2IF_SendprimPkt:
source_id (0x20A), state (0x7), dest_id (0x200), event (0x140),
sapi (0x0), ces (0x1), call_id (0x0),
chan_id (0x0), int_id (0x49A1C22C), free_p (0x1), pkt (0x49A90498), msecs (0x0), priority (0xA)
Oct 17 14:46:21.906: ISDN BR0/3/0 PACKET: L2IF_SendPkt:
chan_id (0x0), int_id (0x49A1C22C), free_pkt (0x1),
pkt (0x4A926E5C), msecs (0x0), priority (0xA)
Oct 17 14:46:21.906: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3B83D1D8), size (4)
Oct 17 14:46:21.906: 0201011F--00000023
Oct 17 14:46:21.906: ISDN BR0/3/0 PACKET: L2IF_SendPkt: Sending from L2
dest_id = 0, source_id = 522, prim = 140
priv_ln = 4, int_id = 1235337772
datastart = 3B83D1C8, netstart = 3B83D1D8, datasize = 20
Oct 17 14:46:21.906: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3B83D1C8), size (20)
Oct 17 14:46:21.906: 49A1C22C0000020A014004040001C2060201011F--00000319
Oct 17 14:46:21.906: ISDN Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Oct 17 14:46:21.906: ISDN BR0/3/0 PACKET: handle_l2d_srq_mail: received:
dest_id = 0x0000, source_id = 0x020A, prim = 0x0140
priv_ln = 4, int_id = 0x49A1C22C, datasize = 4
line_status[12] = IF_ACTIVE
Oct 17 14:46:21.906: ISDN BR0/3/0 Q921r: Net TX ->
Oct 17 14:46:21.906: ISDN Q921d: isdn_l2d_srq_process: event_count 1
Oct 17 14:46:21.906: ISDN L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Oct 17 14:46:21.918: ISDN Q921d: isdn_from_driver_process: QUEUE_EVENT
Oct 17 14:46:21.918: ISDN BR0/3/0 Q921r: Net RX <-
Oct 17 14:46:21.918: 02010115--00000019
Oct 17 14:46:21.918: ISDN BR0/3/0 Q921d: process_rxdata: Frame sent to L2
Oct 17 14:46:21.918: ISDN BR0/3/0 PACKET: L2IF_SendPkt:
source_id (0x200), state (0x0),
dest_id (0x20A), event (0x141),
sapi (0x0), ces (0x0), call_id (0x0),
pkt (0x4C25EB18), msecs (0x0), priority (0xA)
Oct 17 14:46:21.918: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3BB69094), size (4)
Oct 17 14:46:21.918: ISDN BR0/3/0 PACKET: L2IF_SendPkt: Sending from L2
dest_id = 0, source_id = 512, prim = 141
datastart = 3BB69084, netstart = 3BB69094, datasize = 20
Oct 17 14:46:21.918: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3BB69084), size (20)
Oct 17 14:46:21.918: 49A1C22C00000200014104000000C20002010115--000002FB
Oct 17 14:46:21.918: ISDN Q921d: isdn_from_driver_process: event_count 1
Oct 17 14:46:21.918: ISDN L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
Oct 17 14:46:21.918: ISDN BR0/3/0 PACKET: handle_mail: received:
priv_ln = 4, int_id = 1235337772, datasize = 20
C2821-2#
Oct 17 14:46:21.918: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3BB69094), size (20)
Oct 17 14:46:21.918: 02010115AE01954D08028190AC3032AC00000000--0000047F
Oct 17 14:46:21.918: ISDN BR0/3/0 PACKET: handle_mail: received data =
Oct 17 14:46:21.918: ISDN L2_CODE: isdn_l2_process: TIMER_EVENT
Oct 17 14:46:21.918: ISDN L2_CODE: isdn_l2_process: state (0x0), event_count (1)
C2821-2#
Oct 17 14:46:31.918: ISDN L2_CODE: isdn_l2_process: TIMER_EVENT
Oct 17 14:46:31.918: ISDN L2_CODE: l2_timer()
Oct 17 14:46:31.918: ISDN Q921d: l2_timer: timer (0x4E3CED08), timer_type (0x1250)
Oct 17 14:46:31.918: ISDN BR0/3/0 L2_CODE: L2IF_GetDriverID()
Oct 17 14:46:31.918: ISDN BR0/3/0 PACKET: L2IF_SendprimPkt:
Oct 17 14:46:31.918: ISDN BR0/3/0 PACKET: L2IF_SendPkt:
pkt (0x49032844), msecs (0x0), priority (0xA)
Oct 17 14:46:31.918: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3B405998), size (4)
Oct 17 14:46:31.918: 0201011F--00000023
Oct 17 14:46:31.918: ISDN BR0/3/0 PACKET: L2IF_SendPkt: Sending from L2
datastart = 3B405988, netstart = 3B405998, datasize = 20
Oct 17 14:46:31.918: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3B405988), size (20)
Oct 17 14:46:31.918: 49A1C22C0000020A014004550001C2000201011F--00000364
Oct 17 14:46:31.918: ISDN Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Oct 17 14:46:31.918: ISDN BR0/3/0 PACKET: handle_l2d_srq_mail: received:
Oct 17 14:46:31.918: ISDN BR0/3/0 Q921r: Net TX ->
Oct 17 14:46:31.918: ISDN Q921d: isdn_l2d_srq_process: event_count 1
Oct 17 14:46:31.918: ISDN L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Oct 17 14:46:31.922: ISDN Q921d: isdn_from_driver_process: QUEUE_EVENT
Oct 17 14:46:31.922: ISDN BR0/3/0 Q921r: Net RX <-
Oct 17 14:46:31.922: 00010115--00000017
Oct 17 14:46:31.922: ISDN BR0/3/0 Q921d: process_rxdata: Frame sent to L2
Oct 17 14:46:31.922: ISDN BR0/3/0 PACKET: L2IF_SendPkt:
pkt (0x497D5480), msecs (0x0), priority (0xA)
Oct 17 14:46:31.922: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3BB9D694), size (4)
Oct 17 14:46:31.922: ISDN BR0/3/0 PACKET: L2IF_SendPkt: Sending from L2
datastart = 3BB9D684, netstart = 3BB9D694, datasize = 20
Oct 17 14:46:31.922: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3BB9D684), size (20)
Oct 17 14:46:31.922: 49A1C22C00000200014104000000C20000010115--000002F9
Oct 17 14:46:31.922: ISDN Q921d: isdn_from_driver_process: event_count 1
Oct 17 14:46:31.922: ISDN L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
Oct 17 14:46:31.922: ISDN BR0/3/0 PACKET: handle_mail: received:
Oct 17 14:46:31.922: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3BB9D694), size (20)
Oct 17 14:46:31.922: 00010115AC0195074C050181323032AC00000000--00000373
Oct 17 14:46:31.922: ISDN BR0/3/0 PACKET: handle_mail: received data =
Oct 17 14:46:31.922: ISDN BR0/3/0 L2_CODE: L2IF_GetDriverID()
Oct 17 14:46:31.926: ISDN BR0/3/0 PACKET: L2IF_SendprimPkt:
source_id (0x20A), state (0x8), dest_id (0x200), event (0x140),
chan_id (0x0), int_id (0x49A1C22C), free_p (0x1), pkt (0x49A904D8), msecs (0x0), priority (0xA)
Oct 17 14:46:31.926: ISDN BR0/3/0 PACKET: L2IF_SendPkt:
pkt (0x4A9264E4), msecs (0x0), priority (0xA)
Oct 17 14:46:31.926: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3B83BC78), size (4)
Oct 17 14:46:31.926: 0001011F--00000021
Oct 17 14:46:31.926: ISDN BR0/3/0 PACKET: L2IF_SendPkt: Sending from L2
datastart = 3B83BC68, netstart = 3B83BC78, datasize = 20
Oct 17 14:46:31.926: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3B83BC68), size (20)
Oct 17 14:46:31.926: 49A1C22C0000020A014004730001C2060001011F--00000386
Oct 17 14:46:31.926: ISDN L2_CODE: isdn_l2_process: TIMER_EVENT
Oct 17 14:46:31.926: ISDN Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Oct 17 14:46:31.926: ISDN BR0/3/0 PACKET: handle_l2d_srq_mail: received:
Oct 17 14:46:31.926: ISDN BR0/3/0 Q921r: Net TX ->
Oct 17 14:46:31.926: ISDN Q921d: isdn_l2d_srq_process: event_count 1
Oct 17 14:46:31.926: ISDN L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Oct 17 14:46:31.938: ISDN Q921d: isdn_from_driver_process: QUEUE_EVENT
Oct 17 14:46:31.938: ISDN BR0/3/0 Q921r: Net RX <-
Oct 17 14:46:31.938: 02010115--00000019
Oct 17 14:46:31.938: ISDN BR0/3/0 Q921d: process_rxdata: Frame sent to L2
Oct 17 14:46:31.938: ISDN BR0/3/0 PACKET: L2IF_SendPkt:
Oct 17 14:46:31.938: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3BB69094), size (4)
Oct 17 14:46:31.938: ISDN BR0/3/0 PACKET: L2IF_SendPkt: Sending from L2
Oct 17 14:46:31.938: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3BB69084), size (20)
Oct 17 14:46:31.938: 49A1C22C00000200014104000000C20002010115--000002FB
Oct 17 14:46:31.938: ISDN Q921d: isdn_from_driver_process: event_count 1
Oct 17 14:46:31.938: ISDN L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
C2821-2#
Oct 17 14:46:31.938: ISDN BR0/3/0 PACKET: handle_mail: received:
Oct 17 14:46:31.938: ISDN BR0/3/0 PACKET: L2IF_DispPak: packet - start(3BB69094), size (20)
Oct 17 14:46:31.938: 02010115AE01954D08028190AC3032AC00000000--0000047F
Oct 17 14:46:31.938: ISDN BR0/3/0 PACKET: handle_mail: received data =
Oct 17 14:46:31.938: ISDN L2_CODE: isdn_l2_process: TIMER_EVENT
Oct 17 14:46:31.938: ISDN L2_CODE: isdn_l2_process: state (0x0), event_count (1)
here is the config:
interface BRI0/3/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
isdn skipsend-idverify
line-power
Incoming t3 trace - for access 2-10-0.
When you trying outgoing call - was used the same access (2-10-0)?
Sometimes exist problem with outgoing calls - if no established calls - level 1 from remote site deactivated. In this case - or make incoming call (for SAME access) or manage permanent level 1 on remote (Cisco) site.
Return to “Trunk Groups”
