Oxe media server OXE MS installation in a VM
cccengg
Re: Oxe media server OXE MS installation in a VM
Hi TGN.
Now i am stuck on this error. Photo attached
Any Idea
Any Idea
So what you did to move forward?
cccengg
I downloaded the new ISO and then i just move forward ,,, but stuck on hardware errors.
any idea what to do
any idea what to do
cccengg
hardware errors
- Konstantinos.E
So you had a problem with your delivery in first place to move forward than before.
Stange.. its a simple automatic procedure...
Any firewall during the procedure or antivirus ? did you add hardware on your vm that is not necasery ? or again failed to download correct binaries ..
The load is 3.3 gb is large and is possible some files to be corrupted ..it happens sometimes ..
When download stops and restarts in that point there is a possibility to have problems.
When you downloaded the file did you make a retry to recoonect the download?
Alca_holic
cccengg
with my first delivery = yes it stops during download
but when i downloaded sencond time then it goes fine and after that i receive this hard ware error.
can u please see the attached setting and hardware of my OMS VM.
i am doing it in VMware workstation 12
Try enhanced keyboard with true
hi cccengg,
please take in account -> sometimes i'm working... and sometimes i make holidays... so my answers can be delayed from hours to days...
What happens when you boot the machine without ALEDS and the boot iso-image inserted? Do you have the same errors?
regards...
regards...
