Transaction Code Description Details
Re: Transaction Code Description Details
Transaction code colums on the General sheet is already in text format. So, what you need to do, is to change the format of the column A on the CODE sheet also to text
rajansuruli15
Dear Sadim,
I have changed the CODE sheet coloum A format to text and executed the report but the output is still #N/A.
FYI..In sheet1 both colum A & B , the cell formats are i kept as general.
Rajan K.S
Rajan K.S
From what i understand, sheet 1 Column A should also be formated as text
rajansuruli15
Now i have changed the CODE & sheet1 colum as text format. But the generated excel report still i am getting as #N/A error.
try to bring your code sheet into sheet1. maybe the formula has cannot see the code sheet at statistic generation process...
regards...
Gesendet von iPad mit Tapatalk
regards...
rajansuruli15
Hi Tgn,
I tried with same sheet, still i didn't success
I tried with different cell format, still after generate the report its failed to show the description and getting the error as #N/A
Rajan
Rajan
