Run traced and sipdump command in different telnet session
from the sipdump command you can select the option 1
dump the gateway management data
There you can see the number of available licenses, No of initial licenses while making call
SIP Trunk issue
Re: SIP Trunk issue
You think that you have licences or you really have enough licences (spadmin command, menu 2)?
Re: SIP Trunk issue
There is an OXE release bug where it didn't free the licenses after a rare condition... Maybe try a patch if you are sure you have enough licenses for your SIP traffic
seetharam r
Re: SIP Trunk issue
Dear all,
I have rebooted the server itself but the license was not updated .
The license was released only after killing sip motor and running Dhs3_init -R SIPMOTOR command and is working fine now.
