Multi Line on DDI
dvid9976
Re: Multi Line on DDI
Post by dvid9976 »
Hello guys, thank you for your replies
Multiline works fine internally, Im able to make up to 4 calls.
The problem is that I can not get it to work from outside through DDI.
To me, it should be a class of service issue but already checked that :-(
All keys with the same number? In this case - strange, for next calls enough "Incoming DID hold on busy set=1" (And user/multiline properties - not declared "Overflow on busy").
In additional - User/dynamic state user - Camp-on - checked?
enio.eltz
Post by enio.eltz »
Yes, it is strange.
As "Incoming DID hold on busy set=1" and if you have created as many multiline keys as you want with the same number, you should able to receive DDI calls from ISDN trunks as many as the number of multiline keys you have created.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
dvid9976
Post by dvid9976 »
dvid9976
Post by dvid9976 »
vad wrote: 03 Jul 2017 08:15 All keys with the same number? In this case - strange, for next calls enough "Incoming DID hold on busy set=1" (And user/multiline properties - not declared "Overflow on busy").
Yes all 4 keys with the same number..
For multiline properties
Automatic incoming/outgoing seizure=True
Selective filtering=False
Overflow on no answer= False
Overflow on busy=False
Dynamic.user state
Busy camp-on=True
All overflows=False
weird, isnt it?
tgn
Post by tgn »
sry... but nobody asked about the external "trunk"...
how many lines has it... is it a point to point or point to multipoint configuration?
regards...
enio.eltz
Post by enio.eltz »
Hi tgn
Yes, it is a good question. But if he is trying to make up to 4 external incoming calls but trunk configuration has just one access...
How many trunk access is configured on this trunk group?
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
dvid9976
Post by dvid9976 »
It is an E1 Isdn 30 channels; I checked it was not congested at time that I tested
Can you post a readkey for that set?
dvid9976
Post by dvid9976 »
Attached the readkey output
Thank you
Return to “Classes of Services”
