copy start-up to running config
Stoffen
Re: copy start-up to running config
Post by Stoffen »
I dont think you can modify this, as this will be a flaw in the security scheme of the SROS.
Any commands pushed by exec will be executed as if you configured it manually with the user rights of the current user.
However there was a flaw some time ago, where you could access some config you should not been able to.
If you move to \configure service
and from
there do \configure system security , you could actually enter the context even if your user was prohibited.
I do belive this is fixed in SROS15.
So if you want to change this settings, you need to modify the current configuration.
This can be done by: file vi config.cfg
Use VI to edit the config.cfg file, save and reboot.
Or, the best way, get someone with appropriate access to change the security settings for your user.
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
Return to “7750 SR”
