Here the test class I use to encode the image :
package com.alcatel.debug;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.IOException;
import org.apache.commons.codec.binary.Base64;
public class Main {
public Main(){
// input file to read
String inputFile = "C:\\Projets\\Alcatel\\XML_API\\Images de test\\terre2.jpg";
// output file to write data
String outputFile = "C:\\log\\test\\terre2_JAVA.txt";
// read non-encoded data from file
byte[] dataIn = null;
try{
dataIn = readByteFromFile( inputFile );
} catch( Exception e ){
e.printStackTrace();
// encode data
byte[] encodedData = encode( dataIn );
// write data into file
try{
writeByteIntoFile( outputFile, encodedData );
System.out.println("Finish");
* read the file byte by byte
* @param p_file
* @return
* @throws Exception
public byte[] readByteFromFile( String p_filename ) throws Exception{
//load
FileInputStream l_file = null;
try {
l_file = new FileInputStream( p_filename );
} catch (FileNotFoundException e) {
throw e;
//read
if( l_file == null ){
System.out.println("FileInputStream null");
throw new Exception( "FileInputStream null" );
else{
byte[] l_array = null;
try {
l_array = new byte[l_file.available()];
l_file.read( l_array );
return l_array;
} catch (IOException e) {
throw e;
* write byte by byte the given byte array into the given file
* @param p_filenameOut
* @param p_data
* @throws Exception
public void writeByteIntoFile( String p_filenameOut, byte[] p_data ) throws Exception {
FileOutputStream fout;
try {
fout = new FileOutputStream(p_filenameOut);
fout.flush();
fout.write( p_data );
fout.close();
throw e;
throw e;
* encode the given data byte array
* @param data
* @return
public byte[] encode( byte[] data ){
return Base64.encodeBase64( data );
* @param args
public static void main(String[] args) {
new Main();
