Here is it.
Thanks!
No audio on blind transfer from SIP trunk
pmvgrocha
Re: No audio on blind transfer from SIP trunk
Hi pmvgrocha
I may create two SIP TG.
The first as ABC-F to call from OXE to the 3rd party PABX. For example TG ID 0.
The second as ISDN All countries to call from 3rd party PABX to the OXE. For example TG ID 1.
Then you can configure routing No. prefix to TG 0.
And in SIP external gateway you configured to the 3rd party PABX you configure the parameter Trunk group number as 1 (TG ID 1 ISDN All countries).
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
pmvgrocha
Hello Enio,
thanks for your reply.
So, trunk group number defined in SIP external gateway is the one used for receive the call from the 3rd party PABX?
Hi pmvgrocha
Yes, it is. On that parameter "Trunk Group Number".
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
For outgoing call via SIP TG (ISDN all countries) - use ARS prefix (with dialing command table where will be declared SIP gateway id). In system doc - you can find example/ System doc/ IP-PCX Networks/ SIP/ SIP Trunking - SIP trunking configuration examples.
