IP Desktop Softphone over VPN
ludo2k
Re: IP Desktop Softphone over VPN
Post by ludo2k »
Hi, tried here over Sophos VPN, everything is good (cnx or internal call) except when calling or receiving call from outside, I can hear people but they can't hear me, any idea?
Already checked firewall, seems good.
dvid9976
Post by dvid9976 »
did you try to add a rule in the firewall for the traffic going back from the oxe towards the softphone?
fliegerswahn
Post by fliegerswahn »
....to anyone who claims to be smarter than me :)))
need your help!!!!
Thanxx for quick responding!
Alcatel OXO R22/009.002, Softphone R0.01.11
Softphone to Softphone > no problem
Extern to Softphone via VPN > no problem
Softphone (VPN) to Softphone (VPN) >phone rings, connection is made but impossible to speak or listen to each other.
Anytime you have a connection but no audio, it's because of a network problem rather than equipment.
Either routes are not defined, or ports are blocked
fliegerswahn
Thank you very much for your quick response!
Is there any possibility that all softphone calls running over the main unit?
But not „peer to peer“....
fery_s
Post by fery_s »
fliegerswahn wrote: 02 Jun 2020 08:16 ....to anyone who claims to be smarter than me :)))
need your help!!!!
are the both of phone over VPN in a same network lan? do you check the RTP ports in the Firewall? when they are direct talk to each others using "Direct RTP" and when you have no voice between them that's means there is no IP routing between two sub networks or may be firewall block RTP ports.
ludo2k
Post by ludo2k »
ludo2k wrote: 27 Mar 2020 05:36 Hi, tried here over Sophos VPN, everything is good (cnx or internal call) except when calling or receiving call from outside, I can hear people but they can't hear me, any idea?
This is now fixed for me.
We talked to our provider, sysadmin, and voip partner, someone touch something because when we tried again it's now fully working.
It works even with the Android App, not very stable, but it works.
Great solution for working at home when necessary.
junoooni
Post by junoooni »
Sorry guys, was out of touch for long time...my issue was resolved by my Firewall engineer... communication between VPN subnet and PBX subnet was alllowed but required TCP ports and tftp was blocked
Glade you found the issue !
enio.eltz
Post by enio.eltz »
Wrong post. Checking for remove it.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Return to “Ip Desktop Softphone”
