AppTab
ben_DUP
Re: AppTab
Post by ben_DUP »
The appTab form will be updated with a period defined in the NotifyscanPeriod parameters defined in the registration file of your application.
Never had my own projects. In fact I used to work for Alcatel supporting the AAPP partners developping on XML IPTouch and XML API Framework web services, so I have some knowledge about this...
Ben
Re: AppTab
:D great to have you around! You seems to be the guru around here :)
I'm trying to do another application that may behave similar to LanCam skinny application, however, doesn't understand how to make it work. It updates once and then nothing, I made a new post for it. Maybe you can help me also in that one?
Thanks a lot
Return to “XML Presentation Server & TAPI Server”
