Dect Phone Rooming
ahqswitchroom4466
Re: Dect Phone Rooming
Post by ahqswitchroom4466 »
Sorry sir not working
Md Afzal Hossain
System Admin
And not just change PLI.
But manage DECT user with netwok roaming rights (without this set regustered with PLI 31) and register set agait (PBX send parameters during set registration only).
About shell - you need to create DECT sets with checked shell item (for temporary registration during roaming). You cannot to use as shell - usuall registered local DECT set.
sadim
Post by sadim »
Yes Vad is right,
if PLI change, there is the need to unregister/register the dect(s) in order to assume new values
ahqswitchroom4466
Problem Solved
Md Afzal Hossain
System Admin
ahqswitchroom4466
problem solved
Md Afzal Hossain
System Admin
Return to “PWT/DECT System”
