Download voice guide file from oxe
Re: Download voice guide file from oxe
Duel (combat) - because I'm not understand - "even russians" this is good or bad.
Even and odd - this is joke from Alex (another meaning for "even" - number like 2,4..).
Russian words not necessary to translate - nothing intresting. :lol:
alex
Post by alex »
cavagnaro wrote::lol: :lol: odd :lol:
help!
Hi, just kind of word game for us poor-not-native-speakers.
"Even" is not only adverb but an adjective too.
So I can read your post as "even russians" where "even" is an adjective.
So check in you dictionary 8)
:lol: flat russians? :lol: never tought that meaning could make someone become in defense position :lol: not very sure what way you understood... :) language things I believe...
Eliott_DUP
Post by Eliott_DUP »
Is all clear now or is still a description needed?
How to "Download voice guide file from oxe"?
1st: Connect to OXE using FTP program
2nd: Change to the right directory /usr7/vg/flash/std or custom (GPA2,CPU6,...)
OR
2nd: Change to the right directory /usr7/vgadpcm/flash/std or custom (GD,GA,...)
OR
2nd: Change to the right directory /usr7/vg/dhs for dynamic voice guides
3rd: Copy the files in binary mode to your PC.
kevkev
Post by kevkev »
"Is all clear now or is still a description needed?
OR
OR
2nd: Change to the right directory /usr7/vg/dhs for dynamic voice guides"
I Can't find file in this directories. Where else i can find it?
Eliott_DUP
kevkev wrote:I Can't find file in this directories. Where else i can find it?
Which hardware is used?
The GPA,VG,... board has the files directly on the Flash Card plugged into the card.
In this case you can't download the files using the OXE.
You need a special PCMCIA Adapter and driver.
Enter the vgemis command when a guide is played.
Then find the values for neqt then enter tradeq <neqt-value-from-vgemis>
You should see the used hardware now.
You can also use the cr and cpl values and enter config <cr> <cpl>
kevkev
Post by kevkev »
(1)xa000000> config 01 27
Thu Dec 6 15:16:40 UTC 2007
| 1 | 27 | GPA FICTIF|---------- | IN SERVICE | NO PCMS CODE |
--- Inter Crystal Topology ---
| CR | CPL Type Role Free/Tot Role Type CPL | CR |
| 01 | 00 -GD (MAIN ) --- 8/8 --- ( INT_A) INTIPA - 01 | 19 |
(1)xa000000>
GD?
Eliott_DUP
kevkev wrote:GD?
Yes. GD is correct. The path should be /usr7/vgadpcm/flash/std
Try vgstat 1 27 and post the output here.
Is there no incident "0260=Beginning of downloading /DHS3ext/vgadpcm/flash/std/vgadpcm.EN0" or "2500=Dow: file /DHS3ext/vgadpcm/flash/std/vgadpcm.EN0 opening error" in incvisu?
Return to “System”
